Mark Audio CHR-70 Application Thread
Old 7th June 2009, 10:23 AM   #191
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
big impact apparently... did you guys do some measurements as well?
Originally posted by Geek
These are transformed into a completely new and different driver, easily sounding like ones worth a HECKUVA lot more.
<IMO>
The downward dynamic range is brought up to Fostex levels and the soundstage gets a hundred feet added to it.
When I first heard the En process, when Bud switched between them, I described it as "turning the recording from the mono to stereo position". In no other speaker have I heard such a dramatic change with the En process as I did this week with the CHR's.
The top end is cleared up spectacular as well. Sonics wise, it was like in a 2-way, swapping a paper cone tweet to a ribbon. BUT... It's not harsh. It just gets that much more clear and well defined.
We listened to some more delicate female vocals and I could not hear their breath with the non-En. I could quite easily with the En version.
</IMO>
Cheers!
Old 7th June 2009, 10:29 AM   #192
EUVL is offline EUVL  Europe
I was going to ask the same question, but was afraid I would get an answer like :
"the improvement is not measurable but you just have to listen to it... "
or something like that.
Patrick
Old 7th June 2009, 03:43 PM   #193
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
No measures yet. We always listen 1st. To be meaningful we'd need before and after. Frankly i don't need to see them.
And the measures i do, won't be as useful as the ones Mark Fenlon does after i send his set back to him.
If they can figure this out, it may help with meauring these.
http://www.diyaudio.com/forums/showt...hreadid=145096
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd July 2009, 05:27 AM   #194
HareBrained is offline HareBrained  United States
HareBrained's Avatar
Just a quick update on my DCR and my listening system.
First, I finally pulled out the screwdriver and added some more acousta-stuff to the driver chamber. I added "a hand full" in each speaker with half going in the upper corner opposite the inter-chamber port and the other half in the corner opposite that. The improvement was all tonal in the bottom 3 octaves (50-400Hz). It sounds a little more balanced and less strained. I don't think it would be necessary if they were away from the wall or I was able to sit further away.
I finally got the optical digital cable for output from my computer and a PS Audio SL Three is handling the conversion duties. As much as the CD player was an improvement over my audio out from the computer, this is over the CD player. Even listening to a KEXP podcast of Steve Earle, which only 192kbps, sounded fantastic. I still find it hard to fathom that these inexpensive drivers are still not the limiting factor.
I was able to do a little A/B with my NAD C520 player with and without the PS Audio. The PS Audio adds dynamics to the upper midrange and upper midbass regions, and heft and sharpness to the bass. Alone, the NAD is a nice sounding player. The differences are not something you would have identified as missing. But with the PS Audio, it's definitely good to have.
Next on my list is EnABL'ing and doing a FAST. Right now I'm liking the CCS Trio8 and the SEAS L22, although the Dayton RSS265HF has some possibilities.
John
Old 2nd July 2009, 12:49 PM   #195
gychang is offline gychang  United States
any real world sensitivity of the speaker?
considering driving it with t-amp clone.
gychang
Old 2nd July 2009, 01:09 PM   #196
italynstylion is offline italynstylion  United States
italynstylion's Avatar
Those huge Lotus BVR's I made are driven with a sonic impact T amp. It's plenty of power for them to get very loud, trust me.
Old 2nd July 2009, 07:27 PM   #197
I can support that they do get loud. I have been told several times to turn it down by my wife who was down stairs. And given it's the low frequencies that transmit best through walls and floors, I can also attest to it's ~45Hz capabilities.
You're not going to chase anyone out of the room because of the volume but they will fill a 15x15 room fairly well.
John
Old 2nd July 2009, 08:11 PM   #198
thanks, now have to decide on the cabinet style....
gychang
Old 3rd July 2009, 04:14 AM   #199
chrisb is offline chrisb
gychang
me thinks there will soon be almost too many from which to choose - I know we've got a few underway or on the drawing board
like my mind, this space intentionally blank
Old 3rd July 2009, 05:09 AM   #200
frugal-phile(tm)
planet10's Avatar
At least 4 - and that is before you consider "variations on a theme"
dave
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
