Bluerex said:Dave can I buy some drivers? Discount for 3?
You can. 3 breaks up a matched pair (but i don't charge extra for that 🙂)
I did give a discount to a fellow who bought 10.
dave
Scottmoose said:You have to select the driver name, not the picture.
Got it! Thanks.
Update.
Recently been motivated to properly finish off the Sab's. For the last 5 months or so they've been standing on some off cuts of ply to stop them wobbling around on the carpeted floor in the Lounge.
SabShooz have been created 🙂
Glued in the KozzeeeGlideKomfortSock (tm) on the Sab Shooz today, motivated by Colins mamoooth build project.
Sab Shooz finished...
Then took the 2 Sab cabs down to the SabShooShop to get them fitted up with their new dapper footware...
Here they are finally running free in their new shooz...
So, approx 5 months after starting them I've finally finished the Saburo's...
Ta Dah!
DTB
Ta Dah!
DTB
chrisb said:DTB - nice touch
Thanks Chris,
I copied the step deflector dimensions inside the horn opening to give the bases some kind of 'togetherness' with the Sab Cabs.
Well-chuffed😉 🙂
DTB
Those look great, Dave!
Maybe I should steal the idea for my Ziggies.
"Zigma-booties", anyone?
Seriously, the finish makes those speakers look really nice.
Brenton
Brenton
Nice build
Hi
I have a pair of Tangband W4 1320 lying around can this fullrange work in a pair of these horns?
Would it be better to attach/mount the speaker by its magnet inside the cabinet and then press the frontplate on it afterwards. After you divide the frontplate in 3 pieces. The top and bottom of the frontplate should be glued to the cabinet as usual, and only the middleplate that is covering the compression chamber is attached with some kind of rubber seal and screws.
best regards
Uwe
Hi
best regards
Uwe
Hi
best regards
Uwe
There was a thread discussing these drivers, I have a pair. Godzilla made and vented enclosure about .22 cuft that he was happy with. I'll have to find the thread. I was in the process of making a home for mine with the same specs but have gotten sidetracked as usual.
- Full Range
- Saburo's Vs. DTB
