Hi im a newbie here and first of all i love this forum. Im building backloaded horns and im still looking for a small blh enclosure for the Fostex FE 83. Does anyone have an idea? I heard that there is a Nagaoka enclosure for this driver, but couldnt find a plan for it. So if you can help me, please answer. Thx a lot and best regards Thorsten
#2 | |
look at the original Buschhorn MkI enclosure - I think it's about as small a "BLH" as you're likely to find that actually works. http://www.speaker-online.de/bauen/bhorn.htm If you can't read the original German text, the diagram and parts list should be sufficient to build from. This design/folding topology is relatively easy to modify for a 4" driver (i.e. FE126/FE108EZ/FF125K - works best with the 126) Note that optimum performance of this type of design is predicated on using room corners to complete the final section of horn mouth - they will still work without, but be severely limited in the lowest octaves.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#3 |
The Nagaoka Tetsuo F-81 design uses the Fostex 83E. The plans are available in Book #5 of Tetsuo's designs. Book #5 is out of print now though, so it might be hard to find.
#4 |
I think you can find it here:
http://homepage3.nifty.com/spida/eng-page9-1-3.htm I think Clark at Blumenstein Audio sells something like this: http://www.blumenstein-ultra-fi.com/naga.html Good luck and let us now which you decide. |
#5 |
Thanks for your answers. The Buschhorn is well known here in Germany. Works very good with Tangband or Visaton. I ve found a small horn of 40 x 25 x 14 cm on ebay germany. This guy sells em for a lot of money. Ill upload a pic later, maybe someone knows this enclosure
#6 |
Hello,
because of the little Xmax of the driver, better take a double horn i prefer my TROMBONE
http://www.hm-moreart.de |
#7 |
Does anybody know this? I d need a plan for it
#8 | |
Yes, the F-81 was the starting point for the Naga design, which is now pretty heavily evolved. It is definitely viable in stock "F-81" form though. I personally love the small Fostex drivers. harder to please than you think though... they are very resolute, especially in the upper frequencies. gotta feed 'em right. I am having some modded by Dave Dlugos now, actually to offer as an option in the Naga horn... should take things to the next level. -Clark
Http://blumenstein-ultra-fi.com |
#9 |
Thank you all, but i still havent found what i am looking for. The small horn (sse pic) is much smaller. It is just 40 cm high, width is 13,2 cm, depth around 25 cm.
#10 |
I assume you mean this.
Can't guarantee how good it is though. |
| fostex fe107e backloaded horn | hendram | Full Range | 3 | 21st July 2009 02:10 AM |
| Backloaded horn with Fostex FE206E | Arie | Full Range | 1 | 9th February 2008 01:28 PM |
| FS: Fostex FE206E (Decware modified) backloaded horn with Karlson Slot $299 | bbaker6212 | Swap Meet | 4 | 24th September 2007 04:34 PM |
| Recommende Fostex backloaded horn project | rho | Full Range | 2 | 6th May 2007 07:38 AM |
| Large backloaded Fostex horn??? | Circlomanen | Full Range | 13 | 24th April 2005 11:21 AM |
| Page generated in 0.12057 seconds (76.50% PHP - 23.50% MySQL) with 11 queries |
