Okay so this might be subtitled raise your horns?"
6-8 weeks ago I was sick and spent a miserable few days in bed and decided I needed a small system for the bedroom. The only bit of kit I needed was a set of speakers and I had a pair of FE167's hanging around so I built Scott and Dave's Chilli Changs. I've been running them for a few weeks now but held off posting as I was disappointed with them and found this very odd as I have a lot of faith in this pairs work and the guys don't publish bad designs - so I knew it must be something I'd done. So what was wrong - well firstly what's good about them - well almost everything - image - voice - clarity etc etc. What I missed was any semblance of bass - it was there - kinda - but not enough "gain/volume" only on over bassy recordings did it shine. I'd on purposely over stuffed the chamber and eventually removed all of it, which helped the mids. Then yesterday I added stabiliser legs and spikes for my carpet - POW WOW - what a different speaker - bass by the bucket loads (all in the right place). Chilli Changs are a great design guys. Now I know stability and coupling have a big part to play in a speakers performance but would like to hear if anyone else has had this experience. Probably a question for Scott - how low are the Chilli's designed to go - I'm really happy with their new performance but would be interested to Know. Cheers - Phil Build and review - http://www.greenie512.net/greenie512/html/wip.html |
#2 |
I fully agree with you. I built the BK16 kit form Madisound. Of course they sounded great, but I was missing couple of things - bass and wider sweet spot. I got the phase plugs form Dave (Thanks@) and I got a wider sweet spot. Before that I put 3 spikes under each speaker. Like you said the improvement was a fact. I could not believe my ears I have one advice for you. You are better off having 3 spikes under each speaker. 3 points always make a plane. Here are some pics: |
#3 |
Phil:
I'd be interested in hearing how the Chilli Chang sounds compared to the ML TQWT you built earlier (shown on your site). Thanks, Ted |
#4 | ||
#5 |
Hi greenie,
I wonder what your impressions are when you compare the Chang to the Frugal-Horn? I see the FH's were for someone else but you had a good listen right? Cheers! |
#6 | |
I really think we are looking at two completely different beast here and both are first class. Frugal are little (but complex) animals, with a suprabaffle give a much larger sound stage than you'd expect. The FE126e is a great driver with beautiful voicing. If properly corner loaded punch well above their weight for bass. BUT position is everything with them and I'd probably be more happy to have them in a smaller?? room. The Chilli's - well obviously give a "larger" sound and with those double horns one of my mates said if he closed his eyes he couldn't work out where the drivers were! - almost line array effect. Now I have the bass functioning properly there's more than enough without to much worry about positioning. This is the best I've heard the FE167e's sound. I've had the Chilli's in the shed undercoating them today and will put the top coats on Wed/Thur but am getting anxious - I miss them already. |
#7 | |
"Before" they were quite underwhelming. Bass lacking. No zap. Lifeless. "After" they are what I expected to hear the first time. Good amounts of bass, though not what you'd get from (say) an 8" driver. To anyone who hasn't tried the feet ... do it! cheers Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all." |
#8 |
Thanks for that greenie. It's great to read about positive experiences, especially comments like yours, "I miss them already"
Mostly because I understand physics about as well as I understand women, I still get amazed by how such a simple thing as floor coupling can affect a speaker! Now if we could only couple women to the floor, in another room, at the opposite end of the house... wait, that doesn't sound right :/ |
#9 | |
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#10 |
Neato! Yeah, stuffing can make or break everything. Cool spikes too.
| Half Chang or Suzy Chang with Subwoofer? | tripathdude | Full Range | 2 | 15th December 2008 04:47 PM |
| Half Chang or BIB? | tripathdude | Full Range | 2 | 30th November 2008 02:32 AM |
| Half Chilli and Fostex 168es | dawnpatrol | Full Range | 1 | 14th May 2008 09:42 AM |
| Double Chang | gpsmithii | Full Range | 37 | 9th March 2008 06:01 PM |
| Chilli or the G Chang? | bear-hifi | Full Range | 9 | 9th December 2007 10:30 PM |
| Page generated in 0.49398 seconds (19.63% PHP - 80.37% MySQL) with 11 queries |
