| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#201 |
Thanks for the link to the Philips high bays, they must be very expensive, but are high performance, the best by today's standards, for sure.
'"CLO", i.e. constant light output" this makes sense The link to future site works for me, just tried it out, not sure why it does not work for you. @jitter, you have done your homework very well, thanks Rick |
#202 |
They definitely are expensive. The Dutch site of Philips Lighting has a 1,220 pages pdf (called "Licht Pocket 2012") available with all products on the Dutch market, including MSRP (excl. VAT).
The small version costs € 1,060, the big version € 1,670. Roughly 2 times the price of the HID highbay luminaires they're intended to replace (apparently highbay luminaires with fluorescent tubes aren't common over here, the Licht Pocket lists none, so no comparison on prices for that type). The link works for me too, now. Probably a temporary problem. |
#203 |
Stonco TBW654EB4-8 T-Bay II 6-Light T5HO Fluorescent High Bay 120-277V
$135.00USD not including the lamps HID Equivalent600WLight Output30,000+ LumensInput Watts360 Compared to this TCP TCPRADIANT100H 150 Watt Radiant LED Luminaire 120-277V $999.00 USD Lumens11090 Watts150 Watts |
#204 |
That's quite a difference and IMHO it would only be interesting to go for the LED highbay light if the price of electricity were to rise, the price of the luminaire to come down or if replacing tubes would require the rental of equipment to reach the luminaires.
By accident I stumbled on this user review of the newest generation retrofit LED lightbulb using not only blue LEDs but also red LEDs in combination with remote phosphor technology. When the price of this one comes down, it sure looks interesting: 92 lm/W, CRI of 92. |
#205 |
Ah !
combining different colours to create a better CRI? Would they do that if the resulting efficiency is lower than adjusting the phosphors of a blue LED for the improved CRI? |
#206 |
I have not watched the video, but read that the lady took them back to Home Depot, so that tells me enough.
Putting a monochromatic red LED light through phospher, do not understand why. Ask the guy named Roger www.rogiervanderheide.com who answers questions on the Philips web site, he would know why. FYI, pretty well all high bays require a lift or a monkey to service or they would not be called hi-bays. I am surprised that T5HO is not commonly used in Holland considering that is a Philips/OSRAM designed lamp. Rick |
#207 |
The narrator said "a word of caution"
Does the Blue LED emit UV? |
#208 |
Possibly Blue-light_hazard?
#209 | |
They are using blue LED's in the 440-460nm range, UV is in the 200-300nm range, a long way apart, that is one of the LED selling points, no UV. Fluorescents use mercury with it's quantum peaks in the UV range, thus some bleeds through the phosphor and the glass. A FL UV lamp uses quartz, no phosphor at all, so that it does not attenuate the UV as much as regular soda lime glass would. I used to work in fibre optics, there are international standards for light sources such as lasers, which emit highly concentrated light in the visible spectrum. By law, you as a mfg, are to label your product accordingly, if it emits light that is above certain limits. A LED does not fall into this catagory or the LED mfg's would be forced, by law, to label their products accordingly. The wiki article does not address these light levels, just calls them HEV with no numbers. These #'s are availble but I do not have a reference to provide. Last edited by rsavas; 6th December 2012 at 07:10 PM. |
#210 |
Error in my definition of the UV band, should be defined as in the 100-400nm range
Ultraviolet - Wikipedia, the free encyclopedia Should have said a "FL UV sterilization lamp uses a quartz envelope" Sorry Last edited by rsavas; 6th December 2012 at 08:08 PM. |
| LED power on light? | newtube | Tubelab | 2 | 6th March 2010 11:48 PM |
| turned on Aleph 1.2,but LED doesn't Light up | Steve Fay | Pass Labs | 13 | 27th November 2004 10:37 AM |
