diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   LCD TV not turning on (http://www.diyaudio.com/forums/everything-else/187455-lcd-tv-not-turning.html)
argonrepublic 20th April 2011 02:43 PM
I have a Proscan 32LA25Q LCD that is not powering up. When power switch is press the power indicator turns from orange to blue and 5V and 12V power supply outputs become active. It appears that there is no backlight voltage but I will recheck. I aimed a flashlight at the screen to see if there is any LCD activity but could see none.
I would have expected a click (however there are no relays that I can see) or some kind of audible blip from the speakers but there was none.
My search engine results showed a couple of half sentences from fixya.com in regards to backlight circuit capacitors.
BWRX 26th April 2011 06:02 PM
These LCD TVs have lethal voltages on the power supply board, so if you are not experienced with TV repair I would not attempt to fix this yourself. The best thing to start with is the repair or service manual. Like cars, TVs also have service manuals. Sometimes you can find them online for free or for a small fee. This can help you identify where the problem is and even what components may need to be replaced in order to fix it.
argonrepublic 27th April 2011 07:00 PM
This particular television uses a Proview power supply which is also used in many other brands. My research led me to replace 2 9N50CF N channel fets and 2 F105J capacitors. TV is now like new.
Thanks for help.
darkmachine 14th July 2011 01:35 AM
I have the same power supply but I have not been able to find a place to purchase F105J caps. Where did you source yours?
Copyright 1999-2017 diyAudio
