| Equipment & Tools From test equipment to hand tools |
I have long been missing a jig for smaller drivers, and finally I made one
I havent tested it yet, but I suppose it works ok |
#2 |
A few more details
#3 |
Your photos are too small to see.
#4 |
#5 |
Ok,
#6 |
I made a similar jig for small holes too. I find that it works fine until you get below a diameter of 10cm or so (think amplifier front panels). Then I prefer a hole saw in a drill press. What's your experience with routing <10cm holes? Kenneth
Never send a human to do a machine's job. --Agent Smith |
#7 |
I tried it yesterday, and it works like a charm
You only need a few stop and go, with grip changes Practice a bit, and you can do it in your sleep Mind you, I usually dont take more than a few mm depth at a time |
#8 |
I have built a couple of hole gigs with a sliding bar with the pin brazed in it. Next time I think I'll add a threaded adjustment rod over the bar for more precise adjustment. I just make a baffle panel using a Jasper jig. My only complaint is it is in 1/16 increments and we really should have at least 1/32 inch. It sure is easy to set up and trust the numbers.
#9 |
Using a collar and an oversized overlay template works very well, as well. Can get down to very small hole size. Maybe use your jig to cut some themplates?
Doc
Ne timeas a facie mulierum ea ignorare |
#10 | |
I make my templates, then I drive two slightly longer small-diameter brads thru the template with my air-nailer. That secures the template in position for the first cut. For subsequent cuts I just lay the template down and tap it in place with a hammer to set the thin brad pins again without noticeable damage (after filling and painting the teensie holes). For larger shapes, I should have made my templates larger with broader flat areas for the router to sit on, which makes it easier to keep the router vertical without tipping. |
| [USA] Freebie: slightly broken Jasper No 200 circle jig | eRiCdWoNg | Multi-Way | 2 | 2nd September 2005 09:18 PM |
| WTB : Jasper Circle Jig | Cacophonix | Swap Meet | 2 | 23rd March 2005 04:35 AM |
| Looking for Japser Circle Jig | chris ma | Swap Meet | 14 | 6th June 2004 01:02 AM |
| Home made circle cutting jig | nuppe | Everything Else | 3 | 5th June 2004 12:39 PM |
| FS: Plunge router and Jasper circle jig | bsteeves | Swap Meet | 7 | 18th June 2003 05:29 PM |
| Page generated in 0.10787 seconds (80.69% PHP - 19.31% MySQL) with 11 queries |
