#2741 |
Hi !
you need 200W UHE,$89 total, but some UHE is shorter, how long is your burner ?
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html |
#2742 |
looking for a bulb for a sharp xr10x but i guess if you have the entire bulb and reflector for it that would be great. i know it costs more but i dont know with my luck if i would be able to do this without breaking bulb...
#2743 |
Hi gmzombie !
yes! I have this entire bulb , price is $120, shipping is $15
#2744 |
so that is 135.00 total...what are the specs on the bulb itself. is it exactly like the original bulb in lumen and lifespan?
#2745 |
135.00 total with shipping? now what are the lumen and lamp life of the bulb? just like stock?
#2746 |
YWH
A fair while ago I bought a replacement lamp as a spare for when my original needed replacing when I received it from you I asked if I should put it in to test it and use original as spare but you said not to bother well the original is getting dimmer and so I put yours in but nothing...no fan no light just a flashing green light which I assume is a fault error code I then put original back in and worked straight away I assume as the original worked after being taken out there is no reset procedure needed to make new lamp work any idea as to whats wrong how can I test lamp send answer to stevejohn54@live.com.au |
#2747 |
Hi crowsss!
please send the lamp back to me.
#2748 |
before we get to that should I reset the lamp hours option
will this make this new lamp work I didnot do that as was not sure if this would stop me re using old lamp |
#2749 |
ywh have sent a pm but you don't reply
#2750 |
Hello, i am new here .. i have a busted lamp in a Sharp XR-10S ... it lights up for a minute or so and shuts off, i did the bypass mod, now i need a light ... i would like something more powerful so i can use not only in complete darkness what are my options and how much does it cost ?
| Page generated in 0.11926 seconds (70.86% PHP - 29.14% MySQL) with 11 queries |
