Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th October 2006, 05:46 PM   #1
@lf is offline @lf  Bosnia and Herzegovina
Default Philips CD 960
I have Philips CD 960 with four JRC5534 op-amps in output stage. In Philips CD960 tech doc NJM5534
Any direct replacements for this JRC5534 op-amps?
Thanks for advice.
Old 14th October 2006, 06:28 PM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default Re: Philips CD 960
Thanks for advice.
Hi.
Almost any of the better dual opamps will replace the 5534 directly or you could try opa627's on browndog converters.
However, there is a new kid on the block in the form of National Semiconductor's LM4562 which seems to be even better !! Try to get some on the sample program.
Andy
Old 14th October 2006, 07:21 PM   #3
tubenut is offline tubenut  South Africa
tubenut's Avatar
STOP!!!!!!
5534 is single!!!!
5532 dual!!! I know, makes no sense but it is.
Guillaume
Croak Audio Exploration
Old 14th October 2006, 08:46 PM   #4
What about AD825?
And what is the difference between NJM 5534 and JRC 5534?
Old 14th October 2006, 09:02 PM   #5
FastEddy's Avatar
Unless the Google lied: the slew rate and noise rejection of the AD825 is a whole lot better ==> ~10X better.
( 825: http://www.analog.com/en/prod/0,,759_786_AD825,00.html )
( 5534: http://www.njr.co.jp/pdf/ae/ae04059.pdf )
Pin out & voltage requirements are the same / same.
AD825:
-3dB Bandwidth 46MHz
Slew Rate 140V/µs (??)
Vos 1mV
Ib 10pA
Input Noise (nV/rtHz) 12nV/rtHz
Vcc-Vee Supply (V) 10 to 36
Iq per Amplifier (max) 7.2mA
# OpAmps per Pkg 1
Operating Temp Range -40 to +85
Packages SOIC
41 MHz, -3 dB bandwidth
125 V/µs slew rate (??)
80 ns settling time
Input bias current of 20 pA and noise
current of 10 fA/√Hz
Fully specified power supplies: ±5 V to ±15V
Input voltage noise of 12 nV/√Hz
Low distortion: -76 dB at 1 MHz
High output drive capability
Drives unlimited capacitance load
50 mA min output current
No phase reversal when input is
at rail
JRC5534 / NJM5534:
Operating Voltage ( ±3V~±22V )
Single Circuit
With VIO Trim Terminal
Low Input Noise Voltage ( 3.3nV/?Hz typ.@ 1kHz )
Power Bandwidth ( 200kHz typ. )
Slew Rate ( 13V/?s typ. )
Package Outline DIP8,DMP8
Bipolar Technology ...
Input Offset Voltage VIO RS?10k? - 0.5 4 mV
Input Offset Current IIO - 20 300 nA
Input Bias Current IB - 500 1500 nA
Input Resistance RIN 30 100 - k?
Large Signal Voltage Gain AV RL?2k?,VO=±10V 88 100 - dB
Maximum Output Voltage Swing VOM RL?600? ± 12 ± 13 - V
Input Common Mode Voltage Range VICM ± 12 ± 13 - V
Common Mode Rejection Ratio CMR RS?10k? 70 100 - dB
Supply Voltage Rejection Ratio SVR RS?10k? 80 100 - dB
Operating Current ICC RL=? - 4 8 mA
Transient Response Rise Time tR VIN=50mV,RL=600?,CL=100pF,Cc=22pF - 35 - nsec
Overshoot VIN=50mV,RL=600?,CL=100pF,Cc=22pF - 17 - %
Slew Rate SR Cc=0 - 13 - V/?s
Gain Bandwidth Product GB Cc=22pF,CL=100pF - 10 - MHz
Power Bandwidth WPG Vo=20VP-P,Cc=0 - 200 - kHz
Equivalent Input Noise Voltage VNI f=20Hz~20kHz - 1.0 - ?Vrms
Equivalent Input Noise Current INI f=20Hz~20kHz - 25 - pArms
Equivalent Input Noise Voltage 1 en1 fO=30Hz - 5.5 - nV/?Hz
Equivalent Input Noise Voltage 2 en2 fO=1kHz - 3.3 - nV/?Hz
Equivalent Input Noise Current 1 in1 fO=30Hz - 1.5 - pA/?Hz
Equivalent Input Noise Current 2 in2 fO=1kHz - 0.4 - pA/?Hz
Broadband Noise Figure NF f=10Hz~20kHz,RS=5k? - 0.9 - dB
Old 15th October 2006, 09:13 PM   #6
Thanks for the info...
Any other advice?....
Old 16th October 2006, 03:23 AM   #7
FastEddy's Avatar
Other advise?? If you got 'em, use 'em ... the '825 that is ... or something equal. (The pin connections are the same for a whole range of "standard" Op-Amps = )
It might be difficult to tell the audio output differences without instruments, as there are certainly other components around the Op-Amp that are more important to audio quality than the band width & slew rate of the Op-Amps ... but you might see some interesting improvements in quality.
You might also explore cleaning up and clarifying the power supply ... like adding some plasic snubbing caps, etc. = DIY common practices rule.
Old 16th October 2006, 10:05 AM   #8
if you don't want to spend a fortune, try OPA 134 (single) or OPA2134 (dual). Within their price range these are the best you can get.
best
Guido Tent
www.Tentlabs.com
Old 16th October 2006, 10:33 AM   #9
OK. Soldered four AD825 opamps in two hours
CD960 has new opamps and play... Sound is good...
Old 16th October 2006, 10:35 AM   #10
...one more picture...
Thank you FastEddy
If you don't want to spend a fortune, try OPA 134 (single) or OPA2134 (dual). Within their price range these are the best you can get.
Thank you Guido.
Do you have any info where I can find OPA 134 in Europe?
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips cd 931/00 jimraft Parts 1 12th November 2005 05:19 PM
CDM 1 by Philips Kal Digital Source 1 7th June 2005 10:52 AM
Page generated in 0.11776 seconds (83.80% PHP - 16.20% MySQL) with 11 queries
