I can add that the harsh static sound seems to be synchronised with the CDROM motor.
I guess - maybe the cdrom's digital out does not shut down and puts out garbage while spinning the disc. Try another unit and see what happens. You may even use a shielded coax cable to connect a unit inside your PC this way for testing if it does not have a play button.
