Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD63 & CD67 mods list
Old 26th December 2007, 03:55 PM   #8731
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally posted by Malefoda
I removed nothing, these fine Elna RJH are still there. The feed is through U199 wich feeds boths pins you said.
I can not find CD12 and CD13 in your picture and that is puzzling me. The Elnas are CD15 / 16....
Ricardo
RC
Old 26th December 2007, 04:23 PM   #8732
nhinstruments
RCruz's Avatar
Default CD53 SERC
To you all I dedicate this picture.
This player can really sing now.
Ricardo
RC
Old 26th December 2007, 05:15 PM   #8733
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
Ricardo
Just check the Ray's list from first page, it's just like it!
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 26th December 2007, 05:36 PM   #8734
nhinstruments
RCruz's Avatar
Ok so you replaced CD12/13 by some SMD types... that is why I could not see them....
I am now searching for the Fleas....
Old 26th December 2007, 08:06 PM   #8735
Malefoda's Avatar
Hello guys,
any good cable as my CableTalk Broadcat 3 from Missing Audio Link? They do not do this one anymore. Maybe another kit from them?
Thanks.
Matthieu
Old 27th December 2007, 06:02 PM   #8736
JeroenR is offline JeroenR  Netherlands
Anyone got some spare flea boards for sale? I posted a note on pinkfish but no reply.
Thanks!!
Jeroen
Old 27th December 2007, 08:59 PM   #8737
quan is offline quan  Australia
Question marantz 63/67mod
Hi Guys, in regard to marantz 63 mod-putting DAC regulator-is it the same as marantz 67?
Where else would i place the regulator 5 V for decoder/servo etc?
PS- i am also looking for Flea PCB-no reply from PFM for a little while now. Quan.
Old 29th December 2007, 03:53 PM   #8738
nhinstruments
RCruz's Avatar
This seems to be the next best practice i must take.
Hi Matthieu
I want to install a reg in the analog +5v input of the DAC.
Can I use a LM340AT directly or should I upgrade to a LM317 3-terminal positive voltage regulators.
In this case can you suggest a good layout ?
Ricardo
RC
Old 29th December 2007, 05:54 PM   #8739
Malefoda's Avatar
I've no advice for you, I've no skill in electronics, I'm just asking here and applying then
I think a Raygulator is the minimum you should fit.
Old 30th December 2007, 08:12 AM   #8740
Question marantz 63 mod
Hi guys
just built a power supply unit for the Kwak clock and +5V regulators-DAC/Xtal/digital supply-by removing U200/RD01 and Rd04.-tapping power from U261 and ground nearby
Dc offset is 26mV which is fine,
the problem is the sudden cut off of music when playing after few minutes and when switch off and start again then it is ok for a few minutes then it cut off again. In the wholetime the disc is spinning fine. What could be the problem?Many thanks Quan-
Marantz CD63 & CD67 mods listHide this!Advertise here!
