| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
| Thread Tools | Search this Thread |
#531 | |
Classic Ebay bargain! My fave so far that I got was 128 7" bass drivers for about £70. Altho my 2kva isolation tx was a good buy too, think that was £35, or maybe less.
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#532 | |
Magneto the Gravity Man
Ok - I have to ask - what on earth do you do with 128 7" bass drivers??? ( apart from reselling them singly on Ebay for £5 each ) |
#533 | ||
http://www.diyaudio.com/forums/showt...232#post831232 I'm having a go at making my speakers into 3-way by rolling off the current mid/bass section and introducing some extra cabs loaded with these babies. 8 per speaker isobaric push-pull is what I am knocking up right now, and it could be ok, certainly should take a LOT of power. Also, we modified 6 (removed cones, added steel bar across frame, blocks of wood etc.) to use as floorshakers in my friends bassment. We also used 4 in his 'bar' area to bring up the midrange and upper bass in there, just mounted in-wall. So that's 10 down and possibly 16 to use in the current project... Quote:
#534 | |
Ray quote
I gave the option to run it from the standard 12V cct short term. I have my clock running from a 12V audiocom reg supplied from the now barely used +20V rail.
#535 |
My latest modifications: second tranny with rf filter, fast rectifier and some caps for the audio voltages.
Absolutely great players, this marantz series. Franz |
#536 |
One Seriously Addicted to Audio and Electronics
Hi Franz,
Nice job, it's starting to look like a KI already What's the PCB floating above the HDAM cans? Some PSU filtering? Regards, Ray. |
#537 | |
All the modifications are according to Gerald Gessner. The audio part consists just 50% of an OPA2134 followed by the LPF. Franz |
#538 | |
How close does the tray come to the Tx / board?? Do you have a link for this mod?? Andy |
#539 | |
Hi. Did you keep any of the original filter after the DAC or did you change everything as per Thorsten's circuit???? Andy |
#540 | ||
I took out the resistors directly at the outputs of the DAC and connected it to Thorstens filter instead. The circuit sounds very good, but I have some HF noise present in my tweeters. I'm now figuring out if it is radiation from my nearby clock PCB, or because the circuit uses only one output and thus it is not cancelled out in some way. Quote:
Do you have a schematic of the passive circuit you use? Is there any noise residue with this passive circuit? Regards, Ray. |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| 6h5c |
| Page generated in 0.24955 seconds (64.96% PHP - 35.04% MySQL) with 11 queries |
