Tibi, Guido Tent has made it very clear in his experience that the clock will work best if fed from its own 5V supply. so okay, how do I do this?
8V supply for mechanism only - remove L4
Separate 5V supply for clock - ?
Separate 5V supply for everything else needing 5V - ?
Tony,
Separate 5V supply for clock - remove L8 and feed tentlabs supply after L8
Separate 5V supply for everything else needing 5V - feed on V4
Tibi
Tibi, with your toroid and PS PCB, what the maximum voltage I can get out of it? (while keeping expected performance of course)
Output trafo is 2 x 9V with median (center-tapped).
With full-wave rectifier, center-tapped design you can get 9 x 1.4142=12.7278 V after filtering.
With full-wave bridge rectifier you may get 2 x 9 x 1.4142 = 25.4556 V after rectification.
Tibi
Excellent. More than enough to feed a P-A super-reg. What's the maximum current output?
2.7 A
Tibi
As advised by Tibi to my email request for the SHIGA mini KIT I'm registering my interest here for the kit.
Tibi ran out of mini kits and if there is enough interest he will run a small group buy. Please register your interest here if looking for the SHIGA mini KIT
ravid - SHIGA mini KIT x 1
- Digital Source
- Using the new 2012 Shigaclone to create a killer high end transport
