Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st February 2012, 08:18 PM   #1
sp502 is online now sp502  Greece
Default DSD audio over USB: an XMOS Reference Design implementation
Hello all,
I just want to make happy the XMOS USB Audio 2.0 Reference Design owners by announcing
the implementation of the DSD audio over USB open standard (proposed by DCS).
DSD over USB standard bypasses the need for special drivers by using 176.4k/24b PCM samples
to encapsulate DSD data (more info in "Playback of DSD Audio over USB – A Suggested Open Standard")
Detailed info and the modified firmware can be found here:
https://www.xcore.com/projects/dsd-audio-over-usb
In a few words:
The board has test points for the I2S signals where you can easily "hijack" the signal
and route it to any external DAC. (it has an on-board DAC that is not DSD friendly)
The implementation outputs DSD signals on the I2S pins with the following mapping:
1. Bit Clock - SCLK
2. Left channel DSD data - LRCK
3. Right channel DSD data - DAC DATA
It has been tested by fellow diyAudio member adelias with a properly modified version of mpd
in combination with a Sabre32 DAC and it works (and sounds) great.
It accepts all sampling rates and changes DSD/I2S on the fly!
In Sabre32 DAC the same pins accept I2S & DSD, so the DAC also changes between I2S and DSD on the fly.
The only serious drawback is that everything at 176.4kHz sampling rate is treated as DSD,
essentially loosing the ability to playback 176.4kHz PCM files. This is temporary until DCS
finalizes the standard. Until then do not try to playback normal PCM files at 176.4kHz!
Enjoy listening DSD audio!
Old 1st February 2012, 10:08 PM   #2
What does "encapsulate data" mean? I hope that it is straight DSD, not converted to PCM "on the fly".
Old 1st February 2012, 10:59 PM   #3
There is no conversion happening. The PCM 176.4k/24b format is being used as a "carrier".
The true DSD data are being transferred but for reasons explained quite well in the DCS' standard,
a special "header" (10101010) is added in the MSB of each 24b sample and is removed by the USB
device before sending the actual DSD data (the rest 16bits) to the DAC.
A look at DCS' document "Playback of DSD Audio over USB – A Suggested Open Standard"
will enlighten you.
Old 1st February 2012, 11:53 PM   #4
Cool... I love the DSD recordings sound and I have a bunch of SACD's.
But playing straight DSD files was limited to my computer sound card, Foobar2000 and the associated plug-in. Which is done by converting to PCM.
Now, I have to mention that a DSD capable DAC will not decode the eventual DSD programs compressed with Direct Stream Transfer (DST). That should be done in the XMOS, based on MPEG-4 DST (that was published as ISO/IEC 14496-5:2001/Amd.10:2007).
Old 2nd February 2012, 07:18 AM   #5
Sonic, there is another (better) Foobar plugin for DSD/DST decoding over here:
Super Audio CD Decoder - Browse /foo_input_sacd at SourceForge.net
Old 2nd February 2012, 08:14 AM   #6
merlin el mago's Avatar
Thanks for the link.
Old 2nd February 2012, 08:43 AM   #7
The DST compression should be handled at the playback application and not in the USB device,
for various reasons and irrespective of the DSD to USB implementation.
Jackal's link plugin is an example that does DST decoding in the application.
Old 2nd February 2012, 10:33 AM   #8
Agree, it was just a mention. I think I know why cannot be done in the device.
@jackal29a - Didn't know about that plugin. Thanks... looks that it has better options.
Old 2nd February 2012, 09:30 PM   #9
Regarding compatible playback software, here is the link for the mpd with a modified DSD module by Jurgen Kramer.
It is tested and works great!
mpd with DSD over USB support
In case you want to test the firmware without the need of special playback software, use the test file that is mentioned in the project page.
The test file is also a good example for testing how it sounds through a non DSD over USB aware device.
Old 3rd February 2012, 10:58 PM   #10
Thanks sp502. DSD-over-USB output with Music Player Daemon is what I have been waiting for.
I see that "taggsupport" options are listed as:
- none No tagging (default)
- id3only only use id3 tags when available
- native only use the tags native to the file format
- DFF: only artist and title
- DSF: ID3
- id3pref use id3 tags when available otherwise use native one
In terms of tagging our DSD files, I presume that the "native" tags are those created by Korg AudioGate?
And since ID3 tags are non-standard for DSD, what's the best way to add ID3 tags - Foobar with the SACD-plugin?
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 839 Yesterday 11:29 PM
DSD Playback system, DSF Player + USB DDC + DSD Amplifier KOON3876 Digital Source 90 13th May 2012 10:52 PM
XMOS Async USB interface (UAC 2.0) dwk123 Swap Meet 1 16th August 2011 04:01 AM
FS: XMOS USB interface/dac ultrafi Swap Meet 2 27th May 2011 07:32 PM
Pre-amp: INA217 reference implementation jamesd256 Analog Line Level 11 13th June 2010 11:27 AM
Page generated in 0.08220 seconds (77.99% PHP - 22.01% MySQL) with 11 queries
