| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
My Rega planet 2000 has not been working for quite some time and recently I changed the pick-up to the sony kss 213c. I have also changed the 4 units of 1n4003 to 1n4004 as mentioned in post 5 of Rega Planet "power-out".
The problem remains and this is the problem: 1) The player does spin the cd when a cd is put into the tray and the lid closed. The front panel instruction reads "no disc' when I push the play button. I have sent it out for repair before this and the repairman said there was nothing wrong with the motor but he wouldn't figured out what was wrong. Does anyone know of this problem? Thanks |
#2 |
Any help would be appreciated. I'll be using it as a transport.
#3 |
#4 |
Check all the wires coming out of the transport for continuity. I had the same problem in Music hall player .
#5 |
Hi
thanks for reply. The transport is connect to the board via a ribbon cable and I think it is securely connected. What other possibility that may cause the motor not to spin? Thanks |
#6 |
check the lid switch assembly . i think its some kind of magnetic switch. irrc, it will have 3 wires coming from it. also did you remove the shorting wire/blob of solder on the replacement laser?
#7 |
Yes, I did removed the blob of protection solder from the pick-up laser. What would be wrong from the lid switch? Yes, it is a '3 wire switch' with a 'A-41E' inscription on the 'magnectic' piece. But does it does seems to work.
Thanks |
#8 |
Attached are some photos of the lid's switch and connection to the lid.
#9 |
Photos of the transport
#10 |
I believe the voltage is not reaching the transport. But I do not know which components are supplying voltage to the transport. Anyone knows or can advise?
| Rega Planet 2000 MOD??? | Guijs | Digital Source | 1 | 21st June 2006 02:55 AM |
| Rega Planet 2000 | Julius | Digital Source | 0 | 29th December 2004 07:23 PM |
| Rega Planet 2000 | Julius | Digital Source | 4 | 25th November 2004 10:55 AM |
| Upgrading REGA Planet 2000 | Haavard | Digital Source | 1 | 23rd March 2004 05:56 AM |
| rega planet 2000 modified | bourni | Digital Source | 3 | 2nd December 2003 01:09 PM |
| Page generated in 0.09661 seconds (79.28% PHP - 20.72% MySQL) with 11 queries |
