DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 89 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th November 2011, 07:54 AM   #881
erin is offline erin  Australia
Yes, but not on this DAC kit.
Basically you have to try them for yourself as its difficult to pick a winner, its system dependent.
If you want a very generally summary. IMO schottky has less grain, but can sound less dynamic. However there are many schottkies to choose from, the higher current versions tend to have better dynamics.
Regular 1N4007 are pretty good.
Fairchild stealth diodes didn't do it for me. IMO sounded worse than 1N4007.
But really I think its a personal thing. When it comes to diodes I really think you have to try them for yourself to know what works in your system.
Old 19th November 2011, 03:03 PM   #882
smithie is offline smithie  United Kingdom
hi everyone
gonna bite the bullit and get this dac kit...can someone tell me and show the link for the best surplier of this kit as there seems to be quite afew.
many thanks
smithie
Old 20th November 2011, 11:15 AM   #883
Mine came from here - no complaints.
AK4396 DAC Kit 2496 CS8416 24BIT 192K DAC + Transformer | eBay
Old 20th November 2011, 12:37 PM   #884
hi
thanks for that infomation and that was who i was thinking of buying from,so has you had no probs thats good enough for me.
many thanks
smithie
Old 21st November 2011, 10:19 AM   #885
Originally Posted by jnewbold View Post
post #877
Hi in my post above I tried to describe a problem with my DAC. Since then Hello,
I have compared some measurements from a functioning CS8412 chip against the CS9416 chip in this DAC.
I know I am not comparing apples to apples, but as far as I can tell, the following pins are the same function on each chip:
CS8142 pin 12 (SCK) 2.4VDC versus CS8146 pin 24 1.1mV (& 0.01V AC)
CS8142 pin 26 (SDATA) 1.2VDC versus CS8146 pin 26 0mV (& 0.02V AC)
This does not look correct to me. What do others think?
(I also measured the other two data lines between CS8416 and AK4396: pin 27 0.47VDC 1.22VAC) and pin 28 0.67VDC (1.22VAC).
I have ordered a couple of new CS8416 as backup and plan to insert a new one when they arrive.
Any suggestions for anything else to check? I don't have a scope and only a multimeter.
However I do plan to buy an oscilloscope. What would be considered the minimum bandwidth to buy for work on a DAC?
Any help on this would be appreciated.
Old 21st November 2011, 08:43 PM   #886
Default Shorted solder joints
Hi
On the recieved PCB of this DAC I have discovered several shorted solder joints(se fotos).
Is that OK or is it a failure?
/Bjarne
Old 21st November 2011, 10:26 PM   #887
You cant look at the schematic and figure it out?
Old 22nd November 2011, 06:53 AM   #888
Originally Posted by Bjarnevip View Post
Hi
/Bjarne
Those traces are suppose to be like that.
Old 22nd November 2011, 08:49 AM   #889
I have contacted the supplier who says that the shorts at pin 19-20 (Thumbnail 2) should not be there.
/Bjarne
Old 25th November 2011, 03:40 AM   #890
Default The prices for assembeled or not???
Just wondering if im reading this right i'm looking on e-bay and the diy kit is $43 us, and the assembeled version is $48 ? is this correct do others see it like this ? if so is there an advantage to the diy version ? because i would take the assembled one if it means that i don't have a chance to fry anything. Also this thing sounds good enough stock or is the opamp bad ? i've heard lots of different ideas on setups. I'm sure it will beat the crap i'm using now anyway. Just let me know if the prices are right thanks ?
RockON!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
