DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 199 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th July 2012, 11:47 AM   #1981
bcmbob is offline bcmbob  United States
Originally Posted by jean-paul View Post
,,,,,,,. If you guys would like this DAC chip to perform optimally you could think of using WM8804 or WM8805. That will be the mod of mods for this DAC.
Hey Jean-paul,
Can you please expand on this. If I remember correctly you have a lot of good experience with building things from scratch. How would you suggest this mod be accomplished and do you have any experience with an available kit that exploits the features of the advanced WM chips?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 18th July 2012, 05:49 AM   #1982
Ha ha you don't believe that do you ? CS8416 is not good in recovering anything at all. Its crippled by too much functionality and it is not focussed on quality. If you guys would like this DAC chip to perform optimally you could think of using WM8804 or WM8805. That will be the mod of mods for this DAC.
Yes ! Please isolate the BNC from the case. BTW I am not an expert but I think it would be beneficial to use a SPDIF transformer if the DAC is going to be connected with a computer as I see a ground loop there. Maybe a more experienced computer audio enthusiast can shed a light on this ?
What is your opinion of the PCM1794? So far I quite like this chip....
Old 20th July 2012, 05:31 PM   #1983
Toroid replaced with R-Core transformer.
If what I think I'm hearing is real, I regret I didn't use R-core from the beginning. The cleanliness of the sound is outstanding with a brightness that didn't bring any grit or fuzz along with it. Dynamics are great.
My hesitation is based on not having done a direct A/B comparison, but I will build an outboard rig that will allow only the power pads on the PCB to be switched.
If this improvement is real and not a case of hearing what one wants to - I will seriously consider spending the extra to power the Fremen Edition amps with R-Cores.
I'll report after the A/B in a few days.
Bob M.
Old 20th July 2012, 05:34 PM   #1984
Are you serious BCMBOB?!!?? I thought the Toroids supposed to be better.....
How is the Wolfson DAC sounding to the Cirrus Logic?
Old 20th July 2012, 05:45 PM   #1985
Slider, That was my understanding also, and from most of what I have read R-cores are the top choice for preamps and DACs, while toroids are best for power amps. But I am aware that many European and Asian LM3886 builders stick with R-cores in everything. My concern would be with how an R-core would handle the lower mids and bass registers. It's certainly a choice worth investigating. I believe both Dario and linuxguru are using them. Hopefully they will tell us.
Sadly, I haven't had the time to successfully debug the other DAC, but will spend some time on it next week.
Being a glutton for punishment - I'm also taking a look at these developments. ES9023 DAC PCB
Hey, When you want to buy a Steinway in New York, they put you in a room with twenty pianos to choose from. So why should DACs be any different?
Bob M.
Old 20th July 2012, 06:08 PM   #1986
diyAudio Moderator Emeritus
jean-paul's Avatar
Originally Posted by bcmbob View Post
Hey Jean-paul,
This would be a complete redesign or a kind of replacement receiver PCB. I have also bought this AKM DAC and thought about it but I found the DAC chip itself less good than other DACs I have so I did not continue with this.
To be honest I don't bother anymore to put time in DACs that have CS8416 and a DAC chip that could be better. The Wolfsons (but also DIR9001) are the basis for a good DAC at the moment. If I were to find a new DAC (that I don't design myself) I would look for a well designed DAC with WM8804/5 and a WM8741/ESS DAC chip. There must be Ebay "kits" that use those.
Regarding PCM1794: I heard it and liked it but that particular DAC was not mine. Never played with it but I have some PCM chips. For now I am busy with the ES9023. I am waiting for the first guy that compares it to this AKM kit. I think I know which one is better but this is an assumption. One of the builders of our ES9023 DAC finds it sounding better than Oppo 83SE NuForce and a W4S DAC2....
BTW may I suggest to use an isolated version of the fuse holder you have used ? That one seems outright dangerous. There are very nice connector blocks with built in fuse available.
It's only audio. Member of the non modular PCB design committee
Old 20th July 2012, 06:15 PM   #1987
Thanks, another very experienced DAC builder also suggested in a PM, the need for a complete re-work to use the chip. The ES9023 sound very encouraging.
Bob M.
Old 20th July 2012, 06:51 PM   #1988
Reality first!
ClaveFremen's Avatar
IMHO, no way!
R-Cores have measured better performance (according to manifacturers) than toroids in noise, radiated field and regulation...
All parameters that makes them ideal in low signal apps (preamp, DACs ad so on).
Their also very good in high power apps like power amplifiers but are less used since they cost more than toroids.
Subjectively speaking, in my experience, R-Cores sound fuller and more refined than toroids and are deadly quiet.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 20th July 2012, 07:42 PM   #1989
Awesome thanks for the clarification.... Ebay R Core's or something that is a little nicer?
Also I use a CS8416 upsample with a pcm1794.... Upgrading output caps and removing some filters definitely made it sound better
Old 20th July 2012, 07:59 PM   #1990
Reality first!
You're welcome
The ones offered with the DAC are very good quality ones.
Dario
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
