Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th February 2012, 11:50 PM   #1271
kierownik's Avatar
Hi guys. Is anybody using AK4396's digital volume control? Or does anybody know where I can get a controller with firmware for this DAC?
Old 1st March 2012, 06:10 AM   #1272
10y is offline 10y  Italy
Originally Posted by ClaveFremen View Post
And LPF filter caps...
They're only 2€...
Hi Dario,
are they not included in the BOM?
Ciao,
Anto
Old 1st March 2012, 08:09 AM   #1273
Reality first!
ClaveFremen's Avatar
Ciao Anto,
they're included in BOM from the start... (signal path section)
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run
Old 1st March 2012, 10:08 AM   #1274
Solve is offline Solve  Sweden
Solve's Avatar
Is it possible to run this with an single 12V PSU?
Music is the only art in real time....
Old 1st March 2012, 11:41 AM   #1275
Hi there
Many thanks for the replies, i have had the DAC soak testing for about 30 hours so far, i will let it loosen up a little before i do any mods.
If i'm still craving for a little more bottom end after 2-300hours i am going to change out all the capacitors as in Claves BOM for the power supply as a start, Nichicons and elnas on ebay are very cheap
For the time been i will read the full thread page by page.
Many thanks again for all the help
James
Old 1st March 2012, 08:32 PM   #1276
Ciao Anto,
Dario,
thank you.
Old 1st March 2012, 09:47 PM   #1277
zen2003 is offline zen2003  Denmark
Hallo everyone
I am new here, i have asembled the dac kit but i swapped the 7809 with the 7912 in a accident. Now i am not sure that the dac i working. i will not connect i to my system before iam sure it work. My concern is that my friend tells me that the error, 96k and the power led diode will light when no input is connected, but in my case the only led diode is lighting is the power. Iam not sure i have burned some component off.
Another question is, i got a r-core trafo 2*9v and 2*15v, i got 4 set of wires, blue, white is 9v and yellow and brown is 15v but how do i connect it to the dac, i will put the two white in the 2 slot terminal, and one of the yellow and brown in the middle of the 3 slot terminsl, and a yellow and a brown in eatch side of the 3 slot terminal.
Mads
Old 2nd March 2012, 07:40 AM   #1278
hotiron is online now hotiron  Scotland
hotiron's Avatar
With a passive output (Without Opamp). Yes!
If you give up easily Dont start!!
Old 2nd March 2012, 10:05 AM   #1279
Solve's Avatar
Nice!
Just what I planned to do, is it the 0-9v holes I use to the 0-12v?
What caps do you recomend?
Old 3rd March 2012, 11:13 PM   #1280
hotiron's Avatar
Use the 0-9v holes and solder a bridge see photo.
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Page generated in 0.10423 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
