Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Teralink X2 clock mod. with Tentlabs XO
Old 12th December 2010, 11:27 PM   #21
jeffery8341 is offline jeffery8341  Taiwan
Originally Posted by dvb-projekt View Post
Jefery,
your pcb works with +5V (LM1084-5 output = +5V).
What would be interesting is the needed current. BTW, never ever 1A!
Measure the current. If it is under 80mA, you could use the Tentlab plugin shunt.
If itīs more, you could use quanghaoīs Salas shunt here.
I am sure Guido Tent ships also to Taiwan
Hi Oliver, I am using a 12V-1A adaptor for this board at present , the sound quality is very good, I am also sure if I swap the TXCO to Tentlab as you did, sound quality will be much much better, BUT......I am a electronic idiot, I can do a little modification, for example, swap the OP-amp , but if talk about voltage or current, I would rather hang myself....
Oliver, Another question please, my USB sound card is Musiland 01USD, I think if the Teralink X2(before your modification) is better than 01USD, the only reason will be the Teradak TXCO, since I already have a the DSIX board with a better TXCO, do you think I still need to replace 01USD with Teralink X2?
Thanks again.
Old 13th December 2010, 05:21 AM   #22
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Jeffery,
because i donīt know the Musiland, i couldnīt answer this question.
Perhaps some other members do this comparison.
Best,
Oliver
Reference TDA1541A DAC project PCBīs / Tube-I-zator PCB
Stock status in my Blog
Old 13th December 2010, 11:47 PM   #23
Jeffery,
Best,
Oliver
Oliver,
I have google some forum, some people think Musiland 01USD is better, some people think Teralink X2 is better, what I think is the Teralink X2 you midified is definitely better.
There will be a new USB soundcard of Musiland come out in next few months, it is much better than 01USD, 01USD use 50.000-gate FPGA, 01PSD use 250,000-gate FPGA, same as RME9632.
By the way, Oliver, I saw your flag, you are German, so can I ask you a question about a German audio product via PM?
Old 14th December 2010, 02:16 AM   #24
Sure you can
Old 18th December 2010, 01:11 PM   #25
Default Additional modification added
As posted before, i canceled the original TCXO LC onboard filter in the +5V line,
because the Tentlab XO had itīs own at the socket.
2nd modification is the I2S Buffer-IC.
I change the 74HC125 (tPD: 8ns) to the ~53% faster 74VHC125 (tPD: 3.8ns).
This will reduce the added jitter of the Buffer-IC.
At desoldering, i unhitch two solder pads... What a work to fix this problem!
This is no work for rookies
So letīs power up and listen again
Old 19th December 2010, 02:49 PM   #26
ernesternest is offline ernesternest  Europe
ernesternest's Avatar
Curious waiting for sq info ;-)
Old 19th December 2010, 08:18 PM   #27
Iīve made a small SQ info in my Reference DAC thread.
Old 20th December 2010, 04:35 PM   #28
Default Last modification added
Now my last modification is done.
The X2 getīs now the 2nd Salas shunt regulator for the 3.3V line.
Therefore the onboard 3.3V reg. and the 100ĩF cap on itīs output is canceled.
The +5V salas shunt reg goes directly to the downlink side of the USB-Isolator and from there over the USB connector into the X2.
Here you see the shunt modules. The upper one for the +5V line (USB-Isolator downlink & X2), the lower one for the 3.3V line (X2 Tenor chip).
Jesus Christ... ...What an improvement!
That kicks me out of my chair
My recommendation:
Never, and i mean never, let the X2 play with the onboard voltage regulators,
especially the 3.3V one!
I must go back to my chair and listen again
Old 20th December 2010, 06:22 PM   #29
glt is offline glt  United States
Nice project!. Questions: Since the chip is a 3.3v chip, are you feeding a 5V clock? Thanks.
www.hifiduino.wordpress.com
Old 20th December 2010, 07:10 PM   #30
Now my last modification is done....
My recommendation:
Oliver, wow, thanks for your listening impression! I'm really looking forward to applying the mods.......
Cheers Ernst
Teralink X2 clock mod. with Tentlabs XOHide this!Advertise here!
Teralink X2 edodo PC Based 37 22nd December 2011 03:32 PM
Teralink-X2 & Power Supply unit A&B-SYSTEMS Vendor's Bazaar 1 5th October 2010 06:03 PM
Swapping oscillator on a Tentlabs XO Clock3 Groundloops Digital Line Level 3 12th June 2009 08:46 AM
Selling Tentlabs XO Supply Ruach Swap Meet 0 3rd July 2006 06:56 AM
For sale: Tentlabs XO-DAC hifi Swap Meet 0 25th May 2006 02:31 PM
