Do Audiophiles want a stand alone high end HDD source? - Page 14 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
View Poll Results: If someone made a bit perfect low jitter HDD media source, would you buy it?
Yes, if it sounds better than my PC 76 30.89%
Yes, if it sounds better than my CD player 83 33.74%
No, why would anyone want this? 24 9.76%
Yes, I have been wanting something like this for ages. 99 40.24%
Multiple Choice Poll. Voters: 246. You may not vote on this poll
Old 26th August 2010, 02:24 PM   #131
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Hey Erin
No hurry for the pics ( do you ever sleepIt must be 2am in Oz )
Every days a school day! man what a can of worms!
I'm still going to try and pick up a WD mini on the way through Singapore in a couple of weeks. Once settled back in NZ I will have a look into another DAC project as you have listed, I much prefer a kit or scratch building not mad keen on the cost or lack of input on ready made kits.
Anyways thanks for the advise and I will keep an eye on your thread.
Christmas is coming!! Wife might splash out on a BOM from Mouser!
Cheers
If you keep digging in the garden of failure you will eventually find success
Old 26th August 2010, 02:34 PM   #132
erin is offline erin  Australia
Actually its 12.30 AM.
I wish I did not have to sleep.
Old 27th August 2010, 09:30 AM   #133
Originally Posted by erin View Post
Here are the instructions for extracting i2s (philps format) from the WD mini media player.
1) open the case by removing the 4 rubber feet on the bottom of the case then remove the screws
2) remove the board
3) there is a metal EMR shield covering the IC's. You need to remove this shield to get access to the data line of the i2s.
Removing the shield is a bit difficult because of the lead free solder used.
there are six tabs attaching the shield to the PCB. I ended up cutting the centrally located mounting tab and then:
using some fresh solder applied to the next mounting point, and holding the iron tip in place, pry the shield away from the board until the mounting tab is free.
Repeat this process on the next tab until the shield is free at one end and keep doing this until the shield is held only by the far end centre tab, then cut this one off.
Now the shield is removed. (*note: it is probably possible to carefully cut all the tabs, rather than removing with the above method, as the shield seems to be there so the device passes EMR emissions testing, rather than to protect the circuit from interference. The unit works fine without the shield.)
4) there is a SMD resistor array of three resistors. the resistor furthest away from the DAC, and closest to the microprocessor is the one that has the i2s data line.
here you can solder your wire.
5) next to the USB port there is a blank header on the board, here you can access the other data lines.
The pinout of the header starting furthest from USB is as follows:
pin 1 3.3 v
pin 2 gnd
pin 3 master clock
pin 4 left right clock or (word select)
pin 5 unknown - but it is not data - that’s why you have to remove the shield!
Pin 6 bit clock
Now you can connect wires to the bit clock, LR clock and Data and connect these to your DAC
Photo of board attached.
Enjoy!
Old 27th August 2010, 05:40 PM   #134
Dagwood's Avatar
Hi Erin
Thanks for the pics, as they say a picture tells a thousand words.
Cheers
Old 28th August 2010, 11:01 AM   #135
Dagwood,
You are most welcome.
If you want to use a media player as a transport with i2s with your Burr Brown Dac, the TEAC wap2200 Teac WAP2200 : what's inside?
( i think) uses EAIJ (sony format) i2s which should interface directly to your PCM63 DAC. ( but do your own research to confirm this)
Although I don't know what it sounds like and whether this is a viable alternative???
I can highly recommend the WD mini as a genuinely audiophile stand alone HDD music source. Although it sounds better with a flash drive than with the HDD.
I will have to try a USB isolator ADuM4160 USB Isolator board, bare PCB and kits « Circuits@Home and see if this makes an improvement when using a HDD.
Perhaps this is the end of this thread?
I think my question is answered.
There are many people who want a stand alone HDD source of audiophile quality.
What I have built achieves all that I wanted.
I don't have to have the computer turned on to listen to music.
It sounds about 20 times better than my best attempt at a PC source (cPlay + CMP - fully optimised ) It beats or equals many respected CD / SACD players. It gives genuinely good audiophile sound.
A downside is that although it will play 24/96 high resolution files it only outputs maximum 48khz.
I use a little 7" monitor bought from ebay for about $100 connected to the WD mini for viewing the GUI.
There is a remote control. It interfaces to my TDA1541 DAC. I couldn't be happier.
Now i just need to put it neatly into a box.
I cant recommend this highly enough.
I think this project would bring much enjoyment to many people.
happy DIYing!
Old 30th August 2010, 12:22 PM   #136
danny_66's Avatar
Hi Erin,
That's a great solution for having my flacs played on my TDA1541 DAC.
Now I'm using PC(foobar)->PCM2707->I2S->TDA1541A
Are these mods also possible on the WD TV HD ?
Here are some inside pics: New WD Media Player HD Stripped Naked
Danny
Old 30th August 2010, 01:20 PM   #137
Originally Posted by danny_66 View Post
Hi Erin,
Danny
How you are playing music now, is virtually the same as what I was doing.
The WD mini sounds so much better than that.
The new WD HD media player uses a different chipset so I am unable to comment on that. I do believe that it is possible to strip the i2s from HDMI, but I have not done this yet. I think the above mods to the WD mini can be done to the WD live as well, but I am concerned that the network chips in the Live may add some switching noise. That is why I think the Mini is so good, because it is so simple.
Old 30th August 2010, 01:39 PM   #138
danny_66's Avatar
Thanks, then I will try the WD mini, for 40€ it's a no-brainer and it even has a remote :-)
Old 30th August 2010, 01:50 PM   #139
I am looking forward to your impressions. Please write a follow up
Old 30th August 2010, 02:16 PM   #140
bekki is offline bekki  Israel
Although it sounds better with a flash drive than with the HDD...
Hi, Erin!
Maybe the problem with the way of power supply of the HDD, I mean from the USB or external PS? Have you tried both types?
HDD Ultimate Wave Source bra Digital Line Level 12 17th November 2014 09:56 AM
heard that there is a 192K/24bit HDD HI-END player powerpan Digital Line Level 4 21st October 2010 08:39 AM
Can this be a good source? (hdd player with lcd) fcj Digital Source 1 31st October 2006 01:06 AM
high end version of low end phono stage dsavitsk Solid State 20 1st September 2005 11:51 PM
Custom DAC w/HDD source, worth it? RAAMaudio Digital Source 9 14th March 2005 07:18 AM
Copyright ©1999-2017 diyAudio
