Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Sony X5000 troubleshooting
Old 23rd April 2013, 03:07 PM   #191
invisible force is offline invisible force  Germany
I found with my CDP XA7ES the following:
If the ripple on main cap of the display Power supply is above ~ 5Vpp the player starts to click on the analog output, without leaving a trace on the eye pattern! I attached the display power supply (VFD supply) of the cdpx5000 and CDP XA7ES. For the cdpx5000 R974 (22k) is way to high, as this resistor has to take base current of Q971 and leakage current of C972(22yF) - I tend to call this a design error, in my Sony it is 2.2K. So I recommend to put a 3.3k parallel to R974 and raise the main cap C971 to 680yF. Moreover this cap and the rectifier diodes have a strong impact on sound, so best take a silmic. I would replace the rectifier diodes D971-974 to 1A/100V Schottky diodes - smoother sound for some cents..
Do not ask me why Display current leads to clicking - I do not know, but checked it several times...hope this helps, philipp
Old 23rd April 2013, 03:15 PM   #192
dacen is offline dacen  Norway
Hmm, every input is very welcome. Donīt hesitate to make a posting. Some times a fault has itīs mysterious ways.
Old 23rd April 2013, 03:28 PM   #193
Very true..I think the multiplexing circuit of the VFD tube leads to a critical noise voltage drop on the shared main ground bus, thus influencing some digital parts..have fun, Philipp
Old 23rd April 2013, 03:42 PM   #194
some good infos concerning VFD tubes :
Vacuum Fluorescent Display (VFD)
Old 23rd April 2013, 03:47 PM   #195
Salar is offline Salar  Germany
I guess Iīll have to wait to October to check this
- my flat (under the roof) alredy reaches about 23 degress celsius whereas is about 18 degrees celsius outside - too warm to provoke clicking...
Old 23rd April 2013, 03:55 PM   #196
sound will improve considerably with schotky diodes and good cap - the 22k will lead to an unstable regulator - it is intended to low pass filter the zener noise but e.g leakage of the 22yF cap will change with aging and : temperature! - so reference voltage for the regulator will change accordingly..
Old 26th April 2013, 10:19 AM   #197
1000ĩF/63V will work for C971 as well?
Old 26th April 2013, 12:22 PM   #198
Yes 1000yF/63V is o.k...in my Sony I first took a 470yF Panasonic FC (clicking disapeared completely) but I disliked the harsh upper midrange , which is typicall for this type..silmics are more pleasing..good luck
Old 26th April 2013, 04:49 PM   #199
Did replace R974 with 2,2k and C971 with 1000ĩF/63V - and put the player in the fridge (for this purpose, the design comes handy, but donīt do this at home, remember moisturization)
No change, It still clicks when being cold. Could be that the warmup/noclick time has become shorter, but I would not bet on this.
Still, thanks a lot!
All the best, Salar
Old 27th April 2013, 06:37 AM   #200
Hello Salar, do not give up...
Given the small money necessary I would change the remaining three caps in the VFD PSU (C972/C973/C974) and keep the values as in the circuit diagramm..take a look at the voltages with an oscilloscope and watch out for high ripple..for testing purpose I would shorten the fuese resistor R902..voltage drop across R974 should be less than 0.2V..
good luck...Philipp
Sony X5000 troubleshootingHide this!Advertise here!
SONY CDP-X5000... Open house... (No, not for sale... :P) Maniac Digital Source 0 3rd September 2007 04:35 AM
Troubleshooting Sony STR-DE975 dj_vulture Solid State 0 29th May 2007 05:17 AM
Helios X5000 Media Server mike_mcf Digital Source 0 27th January 2007 02:50 AM
Newbie Troubleshooting Sony CD Changer zozeppelin Digital Source 0 15th June 2004 01:03 AM
looking for Sony X5000 Service Manual. tone Digital Source 0 21st February 2003 03:10 PM
