| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Magneto the Gravity Man
Could someone explain exactly how a magnetic clamping device affects reproduction as opposed to a non-magnetic clamp (eg brass) ??
Andy |
#2 |
Why do you assume it does ?
#3 |
I don't !
However, several 'experts' have stated that it does so I am asking for proof or otherwise. Andy |
#4 | ||
Hi Poynton, hi Rfbrw,
I hope you are not including me when you say 'experts'. The opposite is truer in my case... It is only that my ears tell me that my ugly transport produces better sound when not using the powerful magnetic clamp that came stock with it. At least two other people seem to agree... but perception is tricky...I would not bet a finger for it Quote:
The option of discarding it from known theory is risky, also. I was warned by Void: CD PRO 2 - The making of a high end CD Transport Quote:
Occidental view point. Cheers, M
Cheapest horn speakers: https://picasaweb.google.com/lh/phot...eat=directlink |
#5 |
Does the magnetic field rotate?
I seem to remember this coming up elsewhere. I would imagine that the north (or south) pole of the magnet faces the metal disc with the other pole pointing into the air. The magnet may rotate but in my mind, anyway, the field would remain constant. ( minor manufacturing faults disregarded.) A constant non-changing field does not induce any current. Andy |
#6 |
Then, why worry?
#7 | |
I was listening to Shigaraki with magnetic clamp and to me it sounded better than Flatfish with screw in acrylic clamp.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#8 | ||
#9 |
Hi Andy,
Assuming there are no other unintentional effects, it should not matter. The clamp that couples the CD to the table will perform as required. Nothing more will make any difference. As for magnetic clamps, the table forms the other half of the magnetic circuit. Therefore they are stationary with respect to each other. In this case, there will be no moving field to create eddy currents or any other effect. The CD itself is plastic an non-ferrous metal, so no effect there either. The main advantage is that the upper clamp disconnects completely from everything else, so you have a simpler rotating system. A pressure clamp does it's job well, except that the thrust bearing wears and induces vibration into the system. It also couples the chassis or sub chassis to the rotating system at another point. A clamp applied by the user normally uses some form of mechanical means to apply pressure to clamp the CD. The main problem here is that we humans tend to push down, sometimes driving the table downwards. This throws out the the focal distance and may even allow the CD to contact the pickup housing. That and it's more work! In the end, I prefer not to trust human fingers and allow mechanics to take over. Much more reliable and easier too. The magnetic clamp would seem to be the way to go as long as it has been designed without major faults. I had to add that. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#10 |
Anatech.
A good answer. I actually have an open mind on this but could not see on what the "anti-magnet" brigade were basing their stand. As for aluminium and plastic being magnetised .............. Andy |
| Gluing and Clamping | wintermute | Construction Tips | 6 | 25th August 2009 04:09 AM |
| lossless clamping with current sense, how? | zilog | Power Supplies | 5 | 25th July 2008 12:59 PM |
| Disk Needs Help Spinning | delory | Digital Source | 4 | 14th September 2007 08:37 PM |
| Output clamping diodes:When do we need them??? | Leolabs | Solid State | 13 | 8th February 2007 07:58 PM |
| Page generated in 0.10614 seconds (83.51% PHP - 16.49% MySQL) with 11 queries |
