Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th July 2007, 03:38 PM   #21
anatech is offline anatech  Canada
anatech's Avatar
Hi Marc,
You are either going to have to buy from Adcom, or buy that part plus the disc motor. Measure the table height very carefully. Also, the laser may be less expensive from Technics.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 21st January 2009, 12:57 AM   #22
Default Adcom GCD-750 Schematic
I am looking to modify or do a parts upgrade on my GCD 750. I am in need of the schematic, can you send me one. I can not email you, as my account is too new. Thanks, Steve. vacumtubes at yahoo.com
Old 21st January 2009, 03:32 AM   #23
anatech's Avatar
Hi Steve,
I'd love one as well.
Contact Adcom directly. You must have the manual in order to know what you are doing and how that might affect anything else.
A couple pointers. Adcom usually uses pretty good parts but I haven't seen this model. Do not replace anything in the servo or DSP area. This is critical, you can only reduce the performance if you try. I once got a new, under warranty Luxman D-105u. IT didn't work after the owner performed his own "high grade updates to replace the cheap parts installed at the factory". In fact, he was quite put out over what he saw as poor quality. Well, he wrote it off. Not worth repair for two reasons. One, he damaged much of the foil traces on the PCB. Two, He installed new resistors (metal film) and capacitors, film for mica. Of course, most of the caps didn't physically fit. Most of his metal film resistors were inductive (that was a surprise to me!). Lastly, the entire unit needed realignment, that's if the laser survived. He worked in the APC area too.
Long story short, "Sorry sir, your CD player is too badly damaged to service. It's going to cost you less to buy a new one (which was true). He was upset, because he was an engineer (he said). So off he went to terrorize the distributor. I heard about that too!
Please, don't let this happen to you.
-Chris
Old 13th June 2010, 06:44 PM   #24
tiefbassuebertr's Avatar
Default Technics/Panasonic CD mechanism RAE0113Z
From this devices there are a still wide range of suppliers on the web, but when I will order this, I get the message "no longer available"
by this supplier I haven't try this:
Electronic parts market
Therefore I must go another way for replace the laser mechanism by the ACD-11 (ACD11) from Acurus (same laser head model).
I have check out other models with the same mechanism:
1) California Audio Labs Delta transport
2) Adcom GCD-750 (GCD750)
3) TECHNICS SL-PD867 (CD-Changer)
found about
audio-technics lasery w sprzêcie
currently auction:
GittiGidiyor - ?kinci el ve s?f?r elektronikler, bilgisayarlar, koleksiyonlar & fazlas? en ucuz fiyatlarla burada, (Turkey) check item number 22582539
Only the last model is cheap enough for changing the optical pickup. Because this isn't a laser from the SONY KSS-series, the probability of getting defective laser tube is very low. Perhaps the differences to other "RAE" mechanism are not by the optical pick up itself (must been checking). In this case more Technics modells are to use for laser head spender.
If your disc motor not faulty, change only the optical pickup and not the complete mechanism.
Check out also this thread:
Need Transport Help!
File Type: jpg Technics SL-PD-867 aera for model No.jpg (44.0 KB, 32 views)
california audio labs CL-15 traverse deck r.terry Everything Else 0 14th June 2009 11:12 PM
Possible Replacement for My Adcom Fearlessleader1 Everything Else 3 21st April 2007 11:13 PM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 09:09 PM
Help With MP3 Deck Maelfactor Car Audio 5 9th August 2004 01:34 PM
Converting a 4/2 reel deck to a 4/4 reel deck purplepeople Everything Else 2 6th June 2003 12:57 AM
Page generated in 0.10260 seconds (73.58% PHP - 26.42% MySQL) with 11 queries
