Filter brewing for the Soekris R2R
Old 13th March 2015, 07:41 AM   #371
spzzzzkt is offline spzzzzkt  Australia
Originally Posted by jaffar View Post
Paul,
i think it is reasonable to make a minimum/intermediate-phase version with (almost) no pre-ringing, similar to Ayre's 'MP Listen'.
Would be a worthy addition to our filter collection.
Thanks!
I'll need to have a play in rePhase, as I haven't found a way to do minimum/intermediate filters with Octave's filter tools. There is a function in Matlab that does this but it hasn't been ported as far as I can tell.
Superdad mentioned that John S had a script that he used to create FIR filters from Sox. So clearly it is possible to do, but I'd have to try to work out how could be done, and that takes time...
Old 13th March 2015, 08:08 AM   #372
Default More CRaP™
I might have to drop this CRaP™ seeing we already have Schitt doing scat routines...
Anyhow, one more dose to keep things "regular"...
This is loosely modelled on the Dac Magic Linear Phase setting.
The original is -0.1dB @ 20kHz, -10dB at 22kHz, and hits -140dB at some unspecified point - seems to be 23-24Khz.
Obviously this has to be called...
TotalCRaP™'s CRaP™Magic - linear phase (v1)
Both 44.1kHz and 48kHz use the same coefficients.
The 44.1kHz version is
-0.2dB @ 20kHz
-8dB @ 22kHz
-150dB @ 26kHz
and 496 taps.
FIR2 filters have been updated so that they are closer to flat between 20-30kHz. This version is something like -0.04dB @ 30kHz.
That should help fill in time until the toothfairy drops off a MSB Platinum VI for everyone...
Old 13th March 2015, 08:39 AM   #373
bambadoo is offline bambadoo  Norway
Great work. Will be some filter testing during the weekend!
Old 13th March 2015, 09:36 AM   #374
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
Are you guys following the development of mike moffat's dac over at head-fi? He talks about a filter that deals with effects not only in frequency but also in time domain. Maybe we could try something similar?
I'm that guy who finds ways *not* to do things..
Old 13th March 2015, 10:16 AM   #375
Default Pull up your SoX...
No magic or special scripts required, just RTFM...
So it took all of about 30 minutes of "suck it and see" to get 99% of the way...
The sneaky trick is the --plot option. What this does with selected SoX effects is to generate a command file which allows you to plot the transfer curve of the effect in Matlab or Octave.
When I first checked using the manual example the results weren't particularly promising - the resulting file contained a couple of equations of the transfer function and plotting commands.
Next attempt using the rate option that John S discusses in posts linked earlier in the thread was a waste of time. It basically doesn't work with --plot option, so no go.
Having a look through the effects listing I noticed that the "sinc" option used the same switches as "rate" but supported --plot. Now we are getting somewhere....
So after a quick peek at the manual page...
Code:
sox --plot octave /path/to/input.wav /path/to/output.wav sinc -20k -I -n 1016 > plot.plt
Holy CRaP™!! the output plot file contained 1016 filter coefficients!
The sampling rate is based on the input.wav, so you need short (1 second is enough) files with 358.2k and 384k sampling rates for FIR1.
From the SoX "rate" documentation...
Minimum, intermediate, or linear phase response is selected using the −M, −I, or −L option; a custom phase response can be created with the −p option. Note that phase responses between ‘linear’ and ‘maximum’ (greater than 50) are rarely useful.
I'm excited.
Old 13th March 2015, 10:30 AM   #376
lcp is offline lcp  Hong Kong
I have downloaded totalCRaP_rev2 for test. This is the first time to "roll" filter. Everything seems fine. Thanks effort your guys here.
Old 13th March 2015, 10:32 AM   #377
Stixx is offline Stixx  Germany
Stixx's Avatar
You are really beating the CRaP out of it...
Keep going !
www.original-ton.net
Old 13th March 2015, 10:51 AM   #378
nusa is offline nusa  Italy
Originally Posted by spzzzzkt View Post
I'm excited.
Just when I was about to comment very positively on your revised CRaP, you are already at your drawing board with more! Great times ahead, many thanks!
Old 13th March 2015, 02:47 PM   #379
zfe is offline zfe
In my opinion the passband for the higher sampling rate (88,96 and up) FIR1 filters should also only be something up to 20kHz while the stopband can be at higher frequencies than for the 44/48 case. At least I would wish such a filter set as option.
I think the main benefit of the higher sampling rates is that it makes live easier for building nice filters (as well for recording as for playback). All of my high sample rate recordings, I have looked at, have no content above -90dB from 18kHz, or at most 22kHz, on upwards.
... unless they are (or seem to be) converted DSD recordings which have a (noise) signal reaching higher levels above 35kHz again:
Old 13th March 2015, 03:56 PM   #380
MisterRogers is offline MisterRogers  United States
Can you say Audio?
I'm really enjoying CrapMagic! Great work!
-0.2dB @ 20kHz
-8dB @ 22kHz
-150dB @ 26kHz
and 496 taps.
Filter brewing for the Soekris R2RHide this!Advertise here!
Soekris 's DAC implementations Eldam Digital Line Level 1041 10th September 2017 12:00 AM
Sold: Soekris DAM1021 R2R DAC Eldam Swap Meet 6 6th February 2015 08:23 AM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 10:05 PM
project brewing in my head, challenging, but seem like a good way to try new concepts lemans23 Multi-Way 26 11th October 2005 01:29 PM
