Filter brewing for the Soekris R2R
Old 23rd February 2015, 09:02 AM   #181
Eldam is offline Eldam  France
Banned
Hi Paul,
Your post is not completly clear for me !
What is the result ? Upload filter : ok ! Better subjective sound to you than moving the FIR2 after this upload ?
Thanks for the good work
Old 23rd February 2015, 12:32 PM   #182
hop.sing is offline hop.sing  Europe
OK, so I tested most filters and my conclusion is that the MB2 from TNT and bam_comb1 from bambadoo feel closest to the source right now, maybe with the edge at the bam_comb1, it is really nice, keeps the emotional impact and has very little color.
I tested in a loopback configuration (blurring the results due to additional AD and DA conversion of course, but still the only way to do a blind test easily) so I can listen against the original file.
The milder filter slopes of spzzzzkt sound a little bit more coloured than the source, but MinPhaseSlowrev1 is a pleasure to listen to, kind of a bit more exciting than the source file. Very nice!
The winner in the exciting category is NOS, but this one is really coloured, with a very alive bass and prominent highs and a kind of breathing sound, too dirty for me, but I can understand why some people like that configuration.
With the exception of the NOS, all filter configurations sound kind of close to each other (in my setup), and no filter really sucks.
Thanks to all the filter brewers, keep up the good work!
Old 23rd February 2015, 02:30 PM   #183
potstip is offline potstip  Turkey
sox 14.4.2 is out btw...
Old 23rd February 2015, 03:35 PM   #184
rickmcinnis is offline rickmcinnis  United States
Paul,
The last thing I intend to do is to change the intentions of this thread but thought I would mention what I did last night - finally getting a digital system back together.
Since I have not tried changing anything in the DAC - just wanted to hear if it worked I used dBPoweramp to upsample to 24/192 a few recordings and it is pretty dramatic the difference that makes skipping the first set of filters.
Tonight I will (hopefully) install the proper firmware and your filter files and hear what that does. Seems a worthy comparison even though the thought of a 1 TB disk becoming a 100gB disk is a little daunting.
I hope this SOEKRIS project does not end up requiring THAT though I could live with it.
Willl be interesting to revisit what I listened to last night with your new second stage filter in place.
By the way - does the DAC retain the original filters? Do we need to copy them to retain them? Of course, the question could well be who wants to retain them?!
Rick McInnis
Old 23rd February 2015, 04:13 PM   #185
bambadoo is offline bambadoo  Norway
Soekris has posted the original filters in the "original thread"
http://www.diyaudio.com/forums/vendo...ml#post4216998
Old 23rd February 2015, 04:27 PM   #186
Banned
The materials for the listing test are always 16/44 or you tested also some other Fs ?
Certainly we will see the links to the different filters in the Wiki though there are not so much pages in the original thread and this one about the filters... not the ECDESIGN John' thread yet !.
Ah, I will buy a USB to serie adaptator and read DimDim's blog !
Old 23rd February 2015, 04:33 PM   #187
Thanks bambadoo.
I should have looked there.
Take care,
Rick McInnis
Old 23rd February 2015, 04:41 PM   #188
Just 44/16 and just one track, I was actually only listening for the difference to the original file, not the most emotional sound or so....
If you just listen through that DA without a reference, you might easily prefer some colored conversion like NOS, because it kind of sounds like an enhancer :-)
Old 23rd February 2015, 04:42 PM   #189
kuribo is offline kuribo
Originally Posted by rickmcinnis View Post
Paul,
FYI: There are several software players that will upsample on the fly so that you wouldn't have to save upsampled versions. HQPlayer seems to be the best of the bunch. It will resample all the way up to DSD....
Old 23rd February 2015, 05:26 PM   #190
soekris is offline soekris  Denmark
Just so my plans are known:
I'm working on firmware to expand the filters, my plans are:
A) To support 4 FIR1 filters for each sample rate types than can be selected between over the serial port, default will be 2):
1) Linear Phase
2) Medium, optimized mix between Linear Phase and Minimum Phase
3) Soft, mostly Minimum Phase but not that good alias rejection
4) No filter, also called non oversampling, no alias rejection
There should be no reason to upsample elsewhere, the dam1021 have plenty of DSP power to do it in realtime, once the filters are done and tuned.... In principle a PC is way faster, but you can't really load it down to much doing DSP work without making it unusable as a PC....
B) The FIR2 filter will also be modified to be pretty soft....
There will come an official soekris release, all done using rePhase, but it take a little time to make and test all those filters.... Keep working on them here as it give me a lot of input what to do....
Søren
Filter brewing for the Soekris R2RHide this!Advertise here!
Soekris' DAC implementations Eldam Digital Line Level 1069 11th April 2018 04:18 PM
Sold: Soekris DAM1021 R2R DAC Eldam Swap Meet 6 6th February 2015 07:23 AM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 09:05 PM
project brewing in my head, challenging, but seem like a good way to try new concepts lemans23 Multi-Way 26 11th October 2005 12:29 PM
