Soekris 's DAC implementations - Page 65 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 28th March 2015, 06:41 AM   #641
ristar is offline ristar  Singapore
Originally Posted by spikestabber View Post
I made a simple circuit to keep a relay powered that has NC contacts shunting the output when the coil is off, the relay only engages when the DAC has a solid LED output (lock) and the input voltage from the +/-12V power supply is good.
End result, no more speaker pops/crackles during sample rate changes , has a good delayed power on function since the DAM takes a bit of time to boot/lock at powerup, and the poweroff PLOP happens after the relay has already shunted the output.
I can do a schematic later but its just a simple rise/falltime config that feeds an NPN darlington that acts as the 12V coil switch and a normal jellybean NPN used to invert the LED output along with some resistors, diodes and a capacitor. I simply power it off one of the legs of DC power input.
Sounds great! Looking forward to this... Was intending to use arduino to do this once dimdim/glt come up with the core code.
Old 28th March 2015, 11:48 AM   #642
DEQ+TheEnd's Avatar
That would be great!
Old 28th March 2015, 04:42 PM   #643
Originally Posted by DEQ+TheEnd View Post
Anyone believe the LVC595’s could benefit from being thermally connected?
I’ve read somewhere that early R-2R test done by others had problems with uneven on resistance in the 595 device used in their early implementation. Of course the LVC version used here is of much higher quality and If I remember correctly SÝren measured switching speed at 70us.
What I’m thinking is a thin sheet of copper covering all the resistors and LVC595’s. With double sided thermal stickers on each LVC.
Hi DEQ+TheEnd. Did you try the idea with the copper?
CM6631a USB i2S - >R2R Soekris Dac 0.01% -> Truepath -> Magnepan SMG-a (highly modded)
Old 28th March 2015, 04:58 PM   #644
DEQ+TheEnd's Avatar
Hi PanagiotisPapadakos.
No I’ve decided I’m not doing any hardware modifications until filters are sorted out and Soren release firmware including intended functionality. Don’t want to paint me in a corner before all the walls are in place.
Old 28th March 2015, 10:43 PM   #645
No Iíve decided Iím not doing any hardware modifications until filters are sorted out and Soren release firmware including intended functionality. Donít want to paint me in a corner before all the walls are in place.
x2. I'm not prepared to commit to a final hook-up scheme until the dual mono functionality is documented and released. The next firmware release should hopefully eliminate a lot of the unknowns.
I had been looking at the Lundahl transformer options for balanced out but kept coming back to the point that the outlay is roughly the same as buying a second DAM to run a dual mono setup.
Old 29th March 2015, 03:11 AM   #646
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
Which transformers were you considering?
W4S STP-SE - DIY Aleph J - Zu Audio Druid V + Undertone
(Analog) VPI Scout Sig - K&K Audio Maxxed Phono (Digital) microRendu - Bryston BDA-3
Old 29th March 2015, 07:51 AM   #647
TNT is offline TNT  Sweden
I belive this DAC is (as all are more or less) sensitive to acuostical and mechanical feedback. So it should be put into a non vibrating enclosure which is sealed to the outside sound presure. A non metallic one reduce the interference with the signal. Don't use those big bulky metallic boutique connectors - they kill dynamics and and put a low roof on the soundstage. Use single solid core teflon isolated wire.
Old 29th March 2015, 09:00 AM   #648
I am new to DAC, this is my first DAC but feel your idea very interesting!
Do you think which parts of DAC is sensitive with vibrating/sound? Can we cover that specific parts by sound isolate material?
Old 29th March 2015, 09:11 AM   #649
Maybe - but one should be aware of that if something is placed on actual components, that may have adverse electrical effects in itself. The crystal that makes the oscillator is sensitive. Then there seem to be indications that the actual resistors in the array is also sensitive.
Old 29th March 2015, 09:33 AM   #650
I have used some blu-tak under the PCB and over the crystals for both the DAC and my CM6631a card as damping material. I am not sure if it has any effect, since I've been listening the dac like this from the beginning.
The DAC "do you have experience with this dac", Best diy dac for the money? murphythecat8 Construction Tips 9 17th March 2014 07:30 AM
WTB V2.6 PCB for ES9023 / WM8804 S/PDIF DAC ĖSUBBU DAC grufti Swap Meet 0 26th November 2012 05:51 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Sabre DAC implementations SunRa Digital Line Level 1 18th December 2010 04:35 PM
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Copyright ©1999-2017 diyAudio
