| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#131 | ||
Any details on the power input? Quote:
#132 | |
Yes but the output is still direct from es9023. Just leave the potmeter at maximum if not use it. |
#133 | |
Any hint of price and time will be appreciated.But it is still a bit unclear for me, I know only two ways to achive this with ES9023 - 1) as a simple output attenuator which will increase load if it is low resistance but will not work best with cans if high resistance. well there are RCA not jack so its not targeted to cans 2) with output reduction by adjusting voltage reference (VREG pin #6) both ways are ok (and purists always can remove it), but just of curiosity which way you have done it? Thanks.
Yuri |
#134 |
Hi hifimediy
This is from the specifications for TE7022 chip: "Built in IEC60958 professional S/PDIF TX & RX, AES/EBU supported" TE7022L - GFEC If I read this correctly it is capable of receiving SPDIF signal without the addition of a DIR chip. I think pin 33 is marked SPDRX is for this purpose. CS8416 and WM8805 are certainly well regarded DIR but why don't you connect SPDIF input into pin 33 of TE7022 via a pulse transformer? I don't have the detailed datasheet so I am not sure about the setting to utilise this function of TE7022 though
Quan Tran |
#135 | ||
There is a 3rd way to control the volume, use the digital port of te7022. but that will be another product. Quote:
#136 |
@hifimediy. Thanks, that's good to know.
Quan Tran |
#137 |
Thanks Yubing. Good luck with the toy, I'm looking forward to grab one.
Yuri |
#138 | |
running rmaa, i saw a 13.4db drop in noise this way however, this only worked on my laptop. the dac wouldn't connect properly when i tried connecting to my desktop or the music player (pogoplug) i'd intended to use it with. even with gnd still connected (which doesnt really reduce noise very much, 1-2db maybe) it still didn't function properly. i even tried a dummy 100ohm load between 5v and gnd on one of the injectors to no avail. ![]() as a result i've ordered an adum4160 pcb which i plan on hooking the 5v regulator up to. also will try some clip-on ferrites for the usb cable. -matt |
#139 |
#140 |
quantran: This new one looks perfect to build into my headphone amplfier, do you have any ETA when it will be avalible to order? :-)
| TE7022+ES9023 mini toy^_^ | hifimediy | PC Based | 23 | 1st March 2013 07:20 AM |
| New 24/96 usb converters | sendler | PC Based | 0 | 7th October 2010 10:10 AM |
| USB to SPDIF that does 24/96 and works in linux | morfic | Digital Line Level | 0 | 26th June 2009 11:04 PM |
| Musiland Lilo 3 - 24/96 USB to SPDIF? | Kane Williams | Digital Source | 15 | 21st August 2008 12:14 PM |
| m-audio "transit" usb 24/96 dac and digital i/o | Mark Hathaway | Digital Source | 2 | 9th January 2005 05:13 PM |
