DSP Xover project (part 2) - Page 159 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 31st October 2013, 10:34 PM   #1581
chaparK is offline chaparK  Luxembourg
Hi Jiri, yes RIAA is a good idea, thanks!
Najda DSP
Old 1st November 2013, 06:07 AM   #1582
+1. I'm hoping to implement RIAA with my Nadja to compare to an analogue RIAA. Other things to look into first though...
Old 2nd November 2013, 01:02 PM   #1583
For beta testers: I have here a revision with all what we planned except mix FIR/IIR.
If you can test it, please let me know how it goes, thx!
If you're not beta tester, use this file at your own risk ...
Nick
Najda DSP
Old 2nd November 2013, 02:47 PM   #1584
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Is it possible to have channel 1-2 paired an channel 3-4 and 5-6 and so on....
Regards Åke
Old 2nd November 2013, 04:01 PM   #1585
The option to include input processing on the output data is great. When I enabled this option I expected to "see" what I have been measuring. However, the impact of the analog gains is missing (I understand why). I forgot that I increased the overall analog gain while online. I would like to emphasize the need to make the entire gain structure "visible" offline.
Old 3rd November 2013, 12:16 AM   #1586
dahlberg's Avatar
It doesn't seem so
Old 3rd November 2013, 05:44 AM   #1587
dahlberg's Avatar
I was hoping for the possibility of pairing as "Ryssen" described, is that going to be an option or is the 1/5-2/6-3/7.......the only option planned ?
Old 3rd November 2013, 08:09 AM   #1588
UrSv is offline UrSv  Sweden
UrSv's Avatar
Why do you need to pair 1 and 2 (and so forth) rather than 1 and 5? Doesn't it make more sense to pair 1 and 5 in order for the processing load to always be perfectly distributed between the cores? After all the only difference is where you plug in your cable.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 3rd November 2013, 10:14 AM   #1589
Ryssen's Avatar
It would be easyer if like me going to use my own DAC´s,well a little easier to keep it all togethet on the opamp sockels..
Regards Åke
Old 3rd November 2013, 10:46 AM   #1590
Urban is right: the selected pairing is the most natural for the device architecture: it helps balancing the load between both cores.
Also, when you're using the onboard DACs, you'd want to keep one quadruple RCA for one speaker and the other quadruple RCA for the other speaker. It kind of makes sense, and the selected pairing is in line with that logic.
When you use your own DACs, then you're free to route the signals at your will to the expansion port (Menu Settings -> Expansion Port 0 routing). In other terms, nothing prevents you from having two paired channels on the same I2S line if this is what you want.
Najda DSP
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 11:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 06:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 07:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 08:39 PM
Copyright ©1999-2017 diyAudio
