Any good TDA1541A DAC kit? - Page 48 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 8th January 2013, 05:22 PM   #471
Originally Posted by qusp View Post
I must admit to still being a bit confused as to why the pinheader is after the ufls, why not before and have the u.fl facing the other direction? particularly if anyone ever populates both, having a big-*** pinheader directly in the way of what is supposed to be at least somewhat impedance controlled signal when it should he easy for that to not be the case, seems odd to me. I presume you have a reasoning for it though?
Yeah, I'm not sure how I'd be able to route better with them facing the other way. If its ok to route under the ufl on the top layer, why turn it around. But I might not be picturing what you have in mind. Can you sketch it out? Truth is they were just there to be there and I was going to use the ufls. Bear in mind there are restrict areas beneath the connectors. I'm certainly open to better ideas, just having trouble picturing it.
Old 8th January 2013, 06:21 PM   #472
qusp is offline qusp  Australia
qusp's Avatar
yeah I know the restrict is there, I recommended it to you =)
at the moment the pinheader is dominating performance, if the u.fl is what you will use, you are at the moment lowering its performance by the way its sitting in order to have the pin-header.
just roughed this for description, resistor network was just to have something to connect to. rough as guts but you get the idea
as shown the through-holes are still 2.54 pitch, out of the way and works well I think. didnt check it against your layout both sides, can you make this work?
Old 8th January 2013, 06:38 PM   #473
Yes I see now, makes sense. Should be no problem implementing that.
Thanks,
Chris
Old 8th January 2013, 06:43 PM   #474
qusp's Avatar
noticed I had silly spokes on the ground pads, edited and updated, couldnt have that, even on a rough lol
yeah I couldnt see why not either. no dramas.
you could move the row down closer to the u.fl slightly too, but would probably be a pita to solder the header and if the header is secondary, better like this.
Old 8th January 2013, 10:18 PM   #475
erin is offline erin  Australia
Originally Posted by vanofmonks View Post
orse. Not sure why the trace thickness need increasing. They are significantly larger than the signal requires.
From my own experience, the sound from the TDA1541 will be better if you use thicker traces from the output pins. Dont belive me.. do two boards, one with thin and one with thick traces. Tell me which sounds better...
But anyway its your board, do as you wish. I thought you were asking for suggestions.
Old 9th January 2013, 12:23 AM   #476
Default Latest
Here is the latest. It was a bit more involved than I thought, but I think it is better now. I increased audio out trace width. It's now as big as practical I think, and my only point was that electrically, the trace was thick, but could be thicker. Here we go.
Old 9th January 2013, 01:08 AM   #477
Looking good , hopefully Thorsten can leave some informative tid bits if he has not yet already started his own TDA1541A DIY project as he mentioned a while back in this thread
It would be nice to see a 6DJ8/ECC88/6N23P/6N1P output board as an option to this also
Old 9th January 2013, 01:12 AM   #478
looks good.
Old 9th January 2013, 01:56 AM   #479
Default output board
Here is one based on Thorsten's 2005 schematic. The inductors are panasonic with mu metal shields. To save board space, output capacitors are external of the board.
Old 9th January 2013, 02:26 AM   #480
have you got a quote for the boards yet?
Raindrop Hui TDA1541A DAC Kit wushuliu Swap Meet 25 21st November 2013 10:07 AM
which clock for analogmetric tda1541A dac kit Chilli6565 Digital Source 4 6th May 2010 12:41 PM
FS: AYA DAC Rev 2.0b TDA1541A Non-Oversampling DAC kit or complete krishu Swap Meet 0 17th December 2009 09:33 AM
Recommend a DIY tda1541a dac kit? boidos Digital Line Level 2 6th August 2009 01:43 PM
TDA1541A Chineese DAC KIT UV101 Digital Source 8 10th February 2009 10:46 AM
Copyright 1999-2017 diyAudio
