Go Back   Home > Forums > Source & Line > Digital Line Level
Old 26th June 2012, 03:00 PM   #711
iancanada's Avatar
Originally Posted by PET-240 View Post
Just so I follow, if I'm using a USB to I2S device as source I can input direct to FIFO not SPDIF board. However if I want SPDIF input as well I would need to use the back door method?
I'm all for extra functionality as long as I understand.
Also I figure for pause we must wait till buffer empties before music stops?
Yes, the backdoor will work for you if your want to switche between spdif sources and I2S source. However If you just need an I2S input, you even don't need the spdif board .
As well, FIFO will never wait for empties or stops except you put a wrong Fs.
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 26th June 2012, 05:06 PM   #712
Default I2S backdoor
Hi Ian
I was just thinking how to connect my PC Audio USB-I2S into Your re-clocker and hire it is....
Seems You are reading my mind../well probably not only mine../
I'm all for extra I2S input..whatever You will call it...
As for GBII goes .. absolutely I will wait ....
Rosendorfer
Old 26th June 2012, 05:36 PM   #713
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
i'm not even waiting, so dont mind me. will this be available via the FW update when I send mine back for update from beta release Ian?
Old 26th June 2012, 07:08 PM   #714
PET-240 is offline PET-240  Australia
Contributor
G'day Ian,
So to clarify, you made this smart enough so that if the input stream stops, the output stream stops as well? So that if the source is paused, the FIFO effectively pauses as well?
If I'm grasping this correctly, that's bloody marvelous!
So definitely no room for u.fl connectors? Perhaps (another) adaptor board? Or do you feel the input to the FIFO the requirement for the cont imp u.fl's is not required?
Thanks for the efforts Ian, if it's not clear, I'll happily wait!
Old 26th June 2012, 09:48 PM   #715
qusp's Avatar
it does indeed!
Old 26th June 2012, 10:51 PM   #716
Contributor
Thanks for the clarification qusp, I am presuming that is in regards to the pause query?
Old 27th June 2012, 12:07 AM   #717
qusp's Avatar
what else, am I replying to myself above you? =)
no need for ufl there, but you could probably retrofit them easy enough
Old 27th June 2012, 04:51 AM   #718
iancanada's Avatar
Yes, only firmware need to be upgraded. Hardware keeps no any change.
Ian
Old 27th June 2012, 06:35 AM   #719
Ian
Me too, I can't wait and want to send the board to you for FW update immediately.
Old 27th June 2012, 09:59 AM   #720
Contributor
Qusp,
I wasn't sure as I can be counted on to answer most of my own questions, when I ask why? I say it's because I give all the right answers. I know I'm not lying so it must be true......
Must be some Irish in there somewhere......t'be sure,t'be sure.....
See, it makes sense cause I said it.....
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1304 Yesterday 03:43 PM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1724 22nd May 2013 06:50 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Copyright ©1999-2013 diyAudio
