| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#171 |
And wm8805 works in software mode.
#172 |
Is that a prototype of a new product ? With those empty pads, it will be a tweaker's playground.
It will be great if it can have TI or AD SRC chip. And why 2 optical port ? Last edited by i2k92; 18th April 2012 at 03:38 AM. |
#173 | |
I think no problem to use other SRC chips. And there might be a DSD input and up to 8 S/PDIF inputs. so a added optical port is placed because there is still some room. Yubing |
#174 |
BTW, other ports are same as old board.
#175 |
nice .
#176 |
when will the new DAC arrive? also store is currently out of stock.
#177 |
HI, IS IT OK TO BYPASS THE SMD CAPS UNDERNEATH THE MAIN BOARD AND THE SMALL BOARD? THANKS
#178 |
I'm still working on the program. The ouput caps will be same as the old version, so you can choose coupled ouput or directly ouput from chip.
#179 |
please help! my dac will not power up and the dac heats up very hot....the led that indicates lock does not light up.....im still getting 5 volts from the regulator. i bypassed all the electrolytics on the main board and was still playing music then i put in a tube output stage then suddenly the dac will not light up...
please help.....thnks |
#180 |
i removed the small dac board from the main board and the main board led lights up again but when i put the small board back on the led turns off?
| Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 | zog666 | Digital Line Level | 48 | 2nd April 2012 02:48 PM |
| Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! | sharpi31 | Digital Line Level | 2 | 10th January 2011 07:03 AM |
| Gigawork CS4398 DAC +... | McCrackers | Swap Meet | 5 | 30th December 2010 07:30 PM |
| DAC using CS8416 and CS4398 | binspaul | Digital Source | 1 | 29th September 2009 11:37 AM |
| Zhaolu CS4398 DAC board | cotdt | Swap Meet | 3 | 11th April 2007 01:06 AM |
