Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th February 2012, 07:36 AM   #131
UMarcus is offline UMarcus  Germany
the stage are from glass ware audio design. It is a broskie cathode follower board upgraded with Mundorf Caps to convert to unbalanced single end output.
btw.. what is next
I had recently do some test with reclocker (Mutec MC-6, Apoogee Big Ben) and the improvement was quite clearly. I guess the SPDIF Optical out of my pc as clock is worse. I see on spencer page he already do some test with the XMOS Demo Board and it sounds good to me, therefore i order the board and connected via optical out and it sounds better compared to optical pc out. But my goal is to pass the SPDIF by USB > I2S > DAC. The XMOS Demo board provides I2S also, but i never like the idea to connect the PC ground to audio stuff.
For this reason i looking for other solution and found the EDEL USB Audio Interface with galvanic isolation. Including low jitter master clock after isolation stage and possibility to connect external PSU also.
Marcus
Old 15th February 2012, 06:46 PM   #132
BTW, regarding changing 7805 at U11 you can make simple and even better test. Just take 4 1.2V batteries and make parallel connection. It should give about 5.0-5.2V ( check before plugging) in real and you have clean power supply for PCM. My friends tried it and are shocked with SQ improvement. Im gonna test it also.
Old 15th February 2012, 07:25 PM   #133
Just DIY!
pinnocchio's Avatar
Send a message via MSN to pinnocchio
That's nice but how long can you run on 4x 1.2V batteries?
Do
PREAMPs : AMB α10 + JC-80 clone | Balanced DCB1 | AMPs: AMB β24 | Aleph 5 | Symef | Hiraga | ML-2 | Fetzilla | Telos 390 Clone
DACs : TPA Buffalo II + NTD1 I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | Astasia SD | Tubasson Mark 2
Old 15th February 2012, 07:36 PM   #134
what I know you cant make higher voltage than 6.5V for PCM. 5.5 V its ok and Im just testing it.
Its no matter how long you can listen to it - its just test for hardcore modders You have cleanest power supply for PCM. First of all you can observe what it gives to SQ and secondary you can test some discrete power supplies which can be closest to this one If you think its woth it ofc. In my opinion, giving the best possible condition to work for PCM is A MUST, which also you can easily hear. Just check it without spending a lot of money
http://www.voila.pl/347/n6zfq/index.php?get=1&f=1
Old 17th February 2012, 09:05 AM   #135
Hi zibra,
The batteries are only for testing purposes - right?
You are not saying that it sounds better than the discrete reg.
cheers
Old 17th February 2012, 11:35 AM   #136
akira is offline akira  France
Do you pretend you can hear (and recognize) it in blind ABX listening test ?
Old 17th February 2012, 12:12 PM   #137
You can test it by yourself and trust your ears. Cost is almost nothing. I actually tried battery yesterday and for me its the best for pcm. s just magic in music. Only prblem is
with stable voltage for pcm. Just try and let me know! Its so easy to test it!
Old 18th February 2012, 06:51 AM   #138
i want to share some pictures of attached EDEL USB Board.
Up to now it is the best sounding solution how connect pc to FDA i have tested.
Marcus
Old 29th February 2012, 04:17 PM   #139
Hi UMarcus,
Where can I buy the Edel USB Audiointerface?
Manfred
Old 29th February 2012, 06:08 PM   #140
Originally Posted by mb041157 View Post
Hi UMarcus,
Manfred
Hi Manfed,
you can order the board directly by abc-pcb. PM me if you want EMail Address of customer service.
I had post some additional information in this thread.
Marcus
Hum in Balanced Mode in Balanzed Bride Of Zen Erlend Sæterdal Pass Labs 35 12th August 2010 08:17 PM
Help TDA 4X 1541 balanced Mode gil-garcia Digital Source 1 6th December 2007 04:12 PM
Anyone used a PCM1794A with balanced output? hifimaker Digital Source 11 18th March 2006 05:36 PM
PCM1798 mono mode with balanced output help mpopovics Digital Source 8 24th September 2005 10:00 PM
Copyright ©1999-2013 diyAudio
