Behringer DCX2496 digital X-over
Old 12th June 2010, 05:29 PM   #2741
David_Web is offline David_Web  Sweden
Can't you just get rid of the sample rate converter and thus getting rid of the dull sound, if you only will send it 96k?
Or is there more to the problem?
Old 12th June 2010, 06:49 PM   #2742
oettle is offline oettle  Germany
Please see post 2691. Your data source would have to be 100% synchronous to the DCX clock. That means your data source needs to use the DCX clock instead of a local clock. Typically that’s impossible.
Old 12th June 2010, 06:52 PM   #2743
doug20 is offline doug20  United States
Originally Posted by oettle View Post
Spending $650 for two AS2.100 means spending about $200-250 for the two included crossovers.
What is the addition $200-250?? $650 is the total $$$ for 2 AS2.100 which will run two main speakers (2 amps, 2 XOs).
The DCX is $300, The mod is $500, 4 channels of amplification is $500 = $1300.
btw, Im not interested in your opinion one what has better SQ because we live in different worlds.
Old 12th June 2010, 09:09 PM   #2744
I’m sure there is only one world.
btw:
2x AS2.100 (2x€300) = €600 (100dB ADC+DAC)
DCX (€230) + 2x IcePower 125ASX2 (2x€209) = €647 (120dB ADC+DAC, better amps)
SRCmod (€67) + Jan’s active mod (€268) = €399 (low jitter, analog volume control)
Old 13th June 2010, 02:10 AM   #2745
Thanks so its $600 vs $1050.
I didn't know the mod was $400 Euro actually. Are the same links as way, way back in the thread, although Im not sure what the SRCmod is (link?) These mods require some soldering skills, correct?
Old 13th June 2010, 02:30 AM   #2746
On Hiatus
SY's Avatar
They also require much better eyes and finer hand skills than I have. SMD is a young man's game.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th June 2010, 02:45 AM   #2747
BudP is offline BudP  United States
BudP's Avatar
I just tried to buy Jan's active mod from Pilgham, only to find that, in the return email, they made a very cryptic reference to not having any response to an order until early November of this year. No explanation and no real indication that this is the actual time frame.
Just so you know what I found. I intend to leave the order in place, though I think I have 7 days in which to retract it, though again the email had no further information, other than two dates.
Someone who actually knows the folks at Pilgham might want to mention the importance of completeness of information, in return emails, to them.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 13th June 2010, 08:56 AM   #2748
Actually it is €600 vs €647.
So you spend €47 for ~20dB (SNR) better ADCs+DACs and better amps and the possibility for several upgrades e.g.: low jitter clock (€67 SRC/Clock ) and remote analog volume control (€270 DCX 2496 active upgrade ).
So the good old DCX is still not such bad at all and it is still very competitive too.
If you are not able to handle SMD there are build versions (+€50). Without soldering skills you could use Wards modding service for a completely modded DCX (€60+) or you can use the original DCX as it is.
Old 13th June 2010, 09:09 AM   #2749
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Bud
Hi Bud,
I think this must be a fluke. I met Ward from Pilgham last week at a mutual friend and I understood he was still delivering my active mod.
I'll get him to reply to you asap.
jd
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 13th June 2010, 11:17 AM   #2750
Do you have Wards modding service link?
Your numbers just do not add up to all my numbers I have done many, many times over the past two years. Its still comes out to about +$500 US for a decent DCX Mod. Granted I have always looked a the completely built kits. You also assume I would build an amp, That isnt going to happen so I still see this as a $600 vs $1000 debate.
Is $400 really a big deal??? It actually depends.
Behringer DCX2496 digital X-overHide this!Advertise here!
