Go Back   Home > Forums > Source & Line > Digital Line Level
Old 18th May 2012, 02:56 PM   #1001
Just DIY!
pinnocchio's Avatar
Send a message via MSN to pinnocchio
Originally Posted by qusp View Post
indeed its pretty much perfect for this project as is. still looks like a dac chassis, slick looking and enough heatsink for 2 x ntd1, or 1 x ntd1 with shunt regs for the dac and an i2s/clock and dual dac people theres still easy enough alloy and space around to sink to if you need more. in fact I wouldnt really need an external PSU case with this fella provided we get some internal panels for a second floor. though I may still use an external box for AC just so I can use my cannons somewhere hehe.
the LCD type I had in mind was the one that AR2 used, which is actually a Noritake U
type VFD (Vacuum Florescent Display) , a drop in LCD replacement
like I said, if we can get enough of us, they will customize mounting arrangements, holes etc.
I'm interested. It will all come down to final price with shipping
The display looks sharp! Is it HD44780 compatible
Do
PREAMPs : AMB α10 + JC-80 clone | Balanced DCB1 | AMPs: AMB β24 | Aleph 5 | Symef | Hiraga | ML-2 | Fetzilla | Telos 390 Clone
DACs : TPA Buffalo II + NTD1 I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | Astasia SD | Tubasson Mark 2
Old 18th May 2012, 03:19 PM   #1002
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
well being able to use my volume knob will actually mean the difference of me being involved or not, unless I can get him to do a custom size milled and recessed hole for me if it doesnt suit you guys. I got custom made solid titanium volume knobs made for this and my portable (seen below),I designed and modeled them and got them made; not using it is not an option. I must have volume to use the ESS volume control too, I wouldnt have it any other way, even though I will probably use my ipad to set it most of the time. I dont have any volume controls anywhere else in the system other than on my mac. ideally some sort of input selector control would be nice to have too, though again these can be set remotely, its best to have the option of doing it on the front panel.
we could just decide on common ground and leave the rest blank, as for instance getting a hole milled for a recessed volume knob is much cheaper than an LCD hole, so the volume hole could be left to the user to arrange if we cant make it work for all of us. I would like a hole for a momentary too, but that should be fairly easy for us to agree on. I can do up a nice logo for us to get milled into it if desired as well, very simple and not garish, symbolic only
Old 18th May 2012, 03:27 PM   #1003
qusp's Avatar
Do
not familiar with that model not having done a lot of research into displays, but its available in numerous sizes
look at the link I used for god sake!! ha
different sizes
they have much better visibility than LCD, better viewing angle etc its a nobrainer IMO
Old 18th May 2012, 03:40 PM   #1004
Just DIY!
pinnocchio's Avatar
different sizes
Yeah! I saw your link but couldn't find the info in there. I was thinking you might have known but I guess you're not that good! Just Kidding
I found some info on Google and youtube and they seem compatible with the CU-U version 20x4.
Cool!
Old 20th May 2012, 02:27 PM   #1005
qusp's Avatar
ok i've spoken to siliconray, we can get all the customization we want if we can get 20 pieces together, he has not given a price, but says that we will like it. i'm inclined to believe him considering how much cheaper the NCORE guys cases turned out, even with all the customization. this will ideally include:
Front
hole for display
maybe just guide hole made for volume knob
several LED holes, not many needed given the use of a display
hole for momentary switch
possible additions for front panel
• input selector rotary
does the new digital input bopard from TP have a rotary for source selection?• hole for remote reception
• ESS logo, possible nickname 'Hot-Source' ha
REAR
I think this is where people will vary a lot in their options, so really I think we keep the cutouts to a minimum and people can finish themselves. but theres a few things we should be able to agree on.
IEC
USB
BNC?
i'll be using 2 x 4 pin lemo or 1 x cannon for 4 channel output, but will probably get 4 x XLR for legacy
perhaps toslink
I need a second USB, but will be one of those pass throughs, this is for connection to the MCU and carries RS232, so could be DSUB9 or even a mini XLR I guess, as long as it has at least 3 pins
ermm ?? perhaps best to keep this to an absolute minimum so people can do what they wish, but the common and more difficult shapes like USB and IEC
Side heatsink
should be tapped for 2 x D1 minimum and maybe a couple of alternative sets to match the spacing on the Tea-bag salas PCBs. opc can we make it easier for people to snap off the psu this time? just thinking it may or may not be more suitable to mount them to the floor with the IV section on the sink, not imperative, I checked and the D1 as is will fit standing tall, so 2 will fit rather nicely actually. might I suggest that the mounting holes in the corners be increased to M4?
2 x internal panels, 1 vertical wall and one horizontal floor, the floor should probably only extend half way across. the vertical could be used to section off AC
Floor
should be drilled for 4 feet and a transformer or 2, we'll need to chat about this. or just leave it mainly for the individual.
potential GBs
• VFD display from Noritake
• Zfoil power resistors again
• nice quality single deck pot or perhaps stepper like elma
• transformers, actually i'de like to get some of these new cute little pretty reasonably priced 8VA R-Cores from Selectronic for clock, usb and lower power analogue stages, maybe even the IV if they do custom, standard lowish VA units only go up to 2 x 24v secondaries, but the tiny ones are perfect for dac analogue circuits
• LiFePO4 batteries
• momentary switches
• fasteners
i'd like to try to keep my contributions to helping getting the case and panel hardware sorted, someone else can arrange the basic passives parts GB, I get the feeling my choices wont gel with everyone and i'd rather not take it on tbh, the above are just suggestions, not me volunteering to run GBs for them all. someone in the EU to make the R-Core order would be cool, shipping shouldnt be too much as they are so dinky
I welcome input, but lets not get too bogged down in detail just yet
so another list
siliconray RE3220WH GB
link
qusp = 1
hochopeper = 1
opc = 1
______________
total = 3
the cute R-Cores mentioned above
Old 20th May 2012, 02:41 PM   #1006
opc is offline opc  Canada
opc's Avatar
silly qusp...
1+1+1 = 3!
Old 20th May 2012, 02:43 PM   #1007
qusp's Avatar
I dont know what you are talking about??? thats what it says ha
(after ninja edit)
I added you but forgot to change the total
Old 20th May 2012, 02:48 PM   #1008
qusp's Avatar
just a note too, I may depending on timing bow out of a few things and do them later, lots of commitments for my limited coin at the moment, but the chance to get these chassis customized and at a discount is too good to ignore given ive been planning and budgeting to finish a 2 box build of the dac anyway. so I encourage others to please get involved if anything above is of interest to them, dont wait around for me to do it all, it wont happen. the case and the VFD are the main things I want to drive the price down on
Old 20th May 2012, 03:31 PM   #1009
Just DIY!
pinnocchio's Avatar
Same here... Case and VFD and a few holes in the back for XLR, etc... I have all the equipment at home to do everything else.
Old 20th May 2012, 03:33 PM   #1010
Just DIY!
pinnocchio's Avatar
qusp = 1
hochopeper = 1
opc = 1
pinnocchio = 1
______________
total = 4
*** R-Core would need to be dual primaries as well (115/230Vac) for North America.
Click the image to open in full size.[/QUOTE]
Pass Labs S/Ns ? dejanm Pass Labs 8 26th January 2007 07:35 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
Copyright ©1999-2013 diyAudio
