Anybody using the new ESS Vout DAC (ES9022)?
help with jg filter buffer connections
hi guys,
please verify that i made the right connections based on the attached pic. will be using this with a subbu dac.
Thanks guys,
Yes, your sketch is correct.
I see that you installed pin headers which is a good idea... did the same myself 😉
I have the Subbu V3 DAC playing with the JG Filter Buffer and a WaveIO card fed by three psu's
(Subbu and Sjostrom Audio) and am about to case it up.
Sounding very lifelike!
hi Stixx,
i got my jg buffer from a fellow member here.. i was fortunate that he didn't need it anymore.
im very excited to hear how it sounds.. still waiting for a power transformer. I'll be powering it with just an adjustable LM regulator for now.
regards,
Guten Tag mein Herr,
Believed the WaveIO was an USB to I2S ! Is it a USB to SPIDF ? or does this pcb provide also this option ?
Ah Ah😀, don'take this ladder, JP should going to have a Heart attack if you swap the 3 resisitors, scratch the gnd layer for soldering 3 uf.l connectors :faint:
Maybe you can Subbuted a Curryman DAC which is I2S at input... could be a spicy ladder !
