Go Back   Home > Forums > Source & Line > Digital Line Level
Old 16th July 2012, 03:37 AM   #461
EUVL is offline EUVL  Europe
We also have for internal use an adaptor PCB which converts either a single BF862 (SOT23) to TO92, or even a J111 cascoded BF862 into TO92.
If there is sufficient interest, we cam make those available pretty soon.
Patrick
xen-audio.com
Old 19th July 2012, 08:56 AM   #462
jambul is offline jambul  Belgium
Dear Patrick,
May i know what type of cap do you use for the charge pump and neg supply after the mlcc? and what value fo the wima as by pass the regulator to the vref?
Thank you
deni s
Last edited by jambul; 19th July 2012 at 08:59 AM. Reason: forget to add another question
Old 23rd July 2012, 06:40 PM   #463
As agreed with Joachim Gerhard, who kindly offered the filter buffer circuit to all DIYers, here is the arrangement.
We shall offer, in a Group Buy with minimum 25 PCBs, the PCB for the JG Filter Buffer as posted in here :
Anybody using the new ESS Vout DAC (ES9022)?
On the PCB will be soldered a total of 8 Idss matched JFETs (4x BF862, 4x MMBFJ310).
We still need to calculate labour cost for matching and soldering.
But the entire package is likely to be around HK$350 (~44USD) including Paypal fees and registered air mail worldwide.
You will get a Bill of Material so that you can order and solder the remaining components.
This is a one time offer.
After the GB, the board is still available on request, but our normal conditions will apply.
i.e. orders under HK$500 will be subjected to a service charge.
We'll conform exact price in a few days.
Patrick
xen-audio.com
Old 23rd July 2012, 06:42 PM   #464
Sign me up!
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 23rd July 2012, 06:43 PM   #465
You are real quick.
Would you be kind enough to start a GB thread for me (and you) ?
Thanks,
Patrick
xen-audio.com
Old 23rd July 2012, 06:44 PM   #466
Can you say Audio?
I'm in too!
Old 23rd July 2012, 06:45 PM   #467
diyAudio Moderator Emeritus
jean-paul's Avatar
I am in too, not trying = not knowing. Thanks for organizing this.
It's only audio
Old 23rd July 2012, 06:48 PM   #468
I am in too.
Thanks!
Old 23rd July 2012, 06:50 PM   #469
I've opened a GB thread :
Joachim Gerhard Filter Buffer for ES9022
Please check if the entries are correct.
Patrick
xen-audio.com
Old 23rd July 2012, 06:53 PM   #470
buzzforb's Avatar
Me too!
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Balanced jfet buffer for Vout DAC? jonners Solid State 7 22nd October 2010 07:57 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 04:49 AM
Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V Groundloops Power Supplies 14 16th February 2007 01:13 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 07:47 AM
Copyright ©1999-2013 diyAudio
