| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#191 |
my Papa is smarter than your Nelson ! tnx to |
#192 |
#193 |
Sipi is my friend ;
you're baaad Juma !
#194 |
#195 |
#196 |
Master Burner
Juma, thank you for taking look and analyzing. Guys I am little bit unclear. Outside of changing the value of resistor, is there anything wrong with the circuit, because I am just a few days off before sending it for PCB fabrication?
Thanx AR2 |
#197 |
you can use bigger resistors ( in value , not size
) . bigger caps , you can use jumper instead of first darlington ;make these pcbs , and try later what's better .
#198 |
Speaking of PCB fabrication, I'm doing a layout for a new DAC that will be part of my music streaming systems placed around the house. I wanted low power consumption that I could leave on all the time, so I'm using a 2022 based tripath amp being driven by an airport express. I'm building these DACs for better sound from the AE. The DAC design uses a pair of Lundahl LL1690's on the output, so it's germane to this thread (I started a new thread about it, but I'm just getting crickets).
I'm going to have some boards made and if anybody would like to go in on some, I'll adjust my order accordingly. The other thread is here: Yet Another Crystal DAC with Lundahl Outputs |
#199 |
I´m amazed!
![]() Is that a nice square wave? 1kHz with 8.9kΩ load (pot before preamp) across secondaries, no resistor(s) on primaries. Connection diagram:
#200 |
I´m amazed!
I found this very helpful to explain the waveform above, so I want to give this as a reference: I tried to tame the slight overshoot, but had no succes with whatever RC combination.
Far from being obvious, this (klick it) made me stop any further attempts ...
| balanced ouput to transformer | Raj1 | Digital Source | 4 | 7th August 2007 09:34 PM |
| LM4780 - ouput = 4.4v - PB! HELP! | aceditnanar | Chip Amps | 6 | 3rd July 2006 04:10 PM |
| Ouput DC | lawka | Pass Labs | 6 | 15th April 2005 04:31 AM |
| Ouput Stage Distortion | polsol | Solid State | 21 | 14th September 2004 06:35 AM |
| Parallel PP EL84 and ouput transformer question | corbato | Tubes / Valves | 7 | 6th January 2003 01:26 PM |
| Page generated in 0.10008 seconds (70.53% PHP - 29.47% MySQL) with 11 queries |
