Opening the new DacMagic???? - Page 50 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st November 2012, 01:32 AM   #491
Default DacMagic, and DacMagic Plus
I own a Dacmagic, and have followed this thread--The only mod I did was to bypass the output caps ( I had only 1.7mv offset, and I use the balanced outputs) and I replaced the AC supply with an Audio Advisor Pangea supply--just bypassing the caps made a huge difference--thanks for the info in this thread, the new AC supply was better also (larger soundstage).
I was thinking of purchasing a DacMagic Plus (I have a few 176.4 and 192 files and DVD audios) and wondered if anyone has measured the DC offset in the Plus unit, and if the same cap bypass would work in the Plus version? It has the same DACs but I think the output opamps are different. I can't use the new supply as the Plus uses a DC supply. (I can't find a thread on the Plus)
Old 23rd January 2015, 07:54 AM   #492
lucpes is offline lucpes  Romania
Send a message via Yahoo to lucpes
Default USB Input
Does the DACMagic Plus convert usb to i2s or spdif down the chain?
We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines. Measurements can provide a measure of insight, but are no substitute for human judgment. Nelson Pass
Old 24th July 2015, 02:00 PM   #493
tomzzi is offline tomzzi  Slovenia
My DacMagic is "overheating" when running for more than 15-20 mins... Marked area on picture is hot to touch...
Why? Is it normal?
Old 24th July 2015, 07:20 PM   #494
stormsonic's Avatar
Yes, it is normal
Old 30th November 2015, 01:52 PM   #495
Originally Posted by ClefChef View Post
I think what you're hearing is the induction coil, somewhere in power supply, oscillating at high frequencies. It is usually caused by lose ferrite core inside the coil. Determine which one is ringing (do it with a long piece of rubber tube inserted in the ear). You may have to disassemble the coil and put some glue and/or shrink tubing on it.
I had a ringing coil in my DacMagic, i dealt with it by filling it with epoxy - dead silent now.
Is it possible for someone to explain to me where the coils are? I have searched high and low, but sadly I am too much of a beginner.
Love this thread, after receiving my second hand dacmagic, I quickly realised I had a coil whine...
cheers.
Old 30th November 2015, 02:32 PM   #496
Mooly's Avatar
Picture in post # 490. Upper right area, the two round parts with a white dot on them are two obviously visible ones.
Installing and using LTspice IV. From beginner to advanced.
Old 30th November 2015, 02:53 PM   #497
@Mooly,
Thanks for the quick reply! My first diy fix is on the way! No clue yet how to open them up, but I think I'll find a way
Old 30th November 2015, 02:56 PM   #498
Mooly's Avatar
You may not be able to open them, the best you could hope for would be to remove them and fill them with epoxy glue from the bottom.
The outer part on those looks like ferrite which is very brittle.
Old 8th December 2015, 08:59 AM   #499
Thanks for the info, I will try all this during coming weekend. Another questions pops to mind. When the coil is removed from the PCB, filled with hot glue/epoxy. how do I attach the coil back again to the PCB. I have read that hot glue would be possible or is soldering a prefered method?
Old 8th December 2015, 09:36 AM   #500
Mooly's Avatar
They will be soldered onto the PCB (which is most likely double sided with plated vias so be careful), and will be of this general form.
Dacmagic Mods Blue_Max Digital Line Level 55 27th February 2016 01:53 PM
Sony CD-X33ES CD Tray not opening-help? eldarvanyar Digital Source 7 14th January 2008 06:12 PM
Help! Cracks opening in my veneer suzyj Multi-Way 7 28th December 2006 05:42 AM
Cambridge Dacmagic 1 ManUtd Digital Source 1 6th October 2003 11:17 AM
Copyright 1999-2017 diyAudio
