| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1421 |
does the PCM1798 works well with UTC A-20 traffo on the output stage?
#1422 |
Just an update on bypassing the opamp analog output stage and sending the signal to line transformers as posted.
Ended up using Altec 15356A's with the recommend filtering on the input and outputs. Much thanks to Bill Fuss for all his help with this project; he as taken the time to post much of his findings, and also was nice enough to send me PM's with his recommendations on what filter values to use. I have one of the early versions of this DAC, with the coax input transformer and without all those switches to change the sampling. Have the transformers hooked up for only about 24 hours, but can say that it has much promise to be better than my tweaked out "small DAC" with Cinemag 15/15B transformers on the output. IMO - the sound with the Altec transformers on my "big DAC" has more detail and transparancy, and should only get better with a few days burn in. Cheers to all that have contributed to this thread. |
#1423 | |
RIP
#1424 |
Thanks a lot Bill,
I meanwhile found a provider for Neutrik NTL1 transformers which I understand are similar to the Studer used successfully by some experts here. Franz Gysi on first I think. I remember a direct wiring from DAC chip and to outputs without any RC circuit. I'm going to check this on the thread. |
#1425 |
RIP
#1426 |
One can use also 1:1 trafo followed by for example tube stage with gain about 20x
http://www.audiosurgery.beepworld.pl/dacki.htm |
#1427 | |
can you kindly share some gain circuit McGyver? |
#1428 | |
Yes, I can, but not now. So many work to do and the hours are not made of rubber.
http://www.audiosurgery.beepworld.pl/dacki.htm Last edited by McGyver; 28th October 2009 at 05:19 PM. Reason: mistake |
#1429 | |
I tried this out, but the 1 nF had no impact in the visible audioband. I asked David Carter. He told me that the 1k resistors after the Dac were responsible for the early frequency roll off. He was right. I removed them and now I have a perfect frequency response! The sound is extremely good, much better than before, but I do get a very hot signal now. Maybe I should try the windings in paralell instead of in series... Last edited by Lucas_G; 28th October 2009 at 08:11 PM. Reason: Better picture |
#1430 |
Lucas_G
where did you bought LL1674 and how much what Is LL1690 price at that place have you compare sound of Lundahl with other setups |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| A.O.S - Any experience? | Keltern | Multi-Way | 16 | 26th April 2012 11:15 PM |
| my t-amp experience | Eggzy | Chip Amps | 35 | 17th December 2005 06:29 PM |
| Page generated in 0.14980 seconds (74.42% PHP - 25.58% MySQL) with 11 queries |
