| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#121 |
All systems go now. Thanks Dustin.
Dan |
#122 | |
Good to hear Dustin |
#123 |
Hi Dustin,
Thanks for you answers so far. ![]() A couple questions: 1) When is a reset required? 2) Can the chip change input formats on the fly? Say from PCM to SPDIF or DSD? If so is a reset required? Thanks! Russ
Less pulp more juice Twisted Pear Audio. |
#124 |
One more question, I am thinking I should leave XO(pin 23) open (NC) when using an oscillator for clock input?
Thanks! Russ
#125 | ||
1. reset is not really required at all. You can do a chip reset if it somehow get into a wierd state (im speculating) but I've never seen the need for it yet. 2. Yes chip can change on the fly. I would mute the dac's, then change the source, then unmute for a nice smooth transition 3. Yes you can leave XO floating when connecting to an OSC |
#126 |
Hi Dustin,
If I use an external clock source for the ES9008 DAC, does the clock frequency have an effect on the performance of the DAC? The datasheet says the external clock must be >192 x Fs, so for a 44.1KHz input, I'd need a clock of at least 8.4672MHz. The reason I ask is the phase noise of clock oscillators degrades with increasing frequency. If you compare a 10MHz and a 20MHz oscillator from the same device family, same manufacturer, the 10MHz has noticably lower phase noise than the 20Mhz, by up to 10dB! (See this datasheet for example) http://www.rakon-europe.co.uk/pdf/cfpt-5300.pdf So if the ES9008 is flexible with its master clock, would I be correct in saying the best performance would be from choosing the lowest possible external clock? Was thinking 10MHz as this is *the* standard oscillator frequency, available off the shelf for all types of oscillators, right from the cheeziest 40c TTL oscillator, right up to several $100 OCXOs thanks, Len. |
#127 | |
Hi Len, We hanven't notived any significant difference between ocsillator frequencies. My prefference would be to use a fast one over a slower one simply becuase it pushes the quantization noise further out of band. I know I might get flamed over this one in this forum, but everyone needs an opinion. Thanks Dustin |
#128 |
Hi Dustin, Here is my schematic for the DAC PCB.
I have decided to do the controller off board or to utilize my existing "uber controller' board. ![]() But I think it will work great as the default mode is PCM/I2S and I have modules already that output I2S. The board is for stereo output only. I/V filtering is done on another PCB which will stack with this one. Will post PCB pics in a while. Does the schematic look ok? Cheers! Russ
#129 |
top
#130 |
The cap in the center of the DAC chip bypasses VDD(1.2V) for the chip. It forms a star point.
| Page generated in 0.12362 seconds (77.61% PHP - 22.39% MySQL) with 11 queries |
