Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 1st December 2011, 06:27 AM   #11
Francec is offline Francec  Australia
Banned
I've built a circle cutting jig for my plunge router based on the attached. I've added aluminium guides down each side of the base plate and it is very secure.
What I need is a pivot pin; one that canned be screwed into place into several points along the length of it.
Does anyone have any suggestions, please?
Bump for suggestions.
Old 1st December 2011, 05:57 PM   #12
Default Pivot pin
Why not just a simple wood screw with a round head? Standard nails will work also.
Old 3rd December 2011, 12:31 PM   #13
dangus is offline dangus  Canada
See the picture of my plywood circle guide. Just a slot with a T-nut and a bolt. Infinitely adjustable. It needs a relatively big pivot hole, but it fits securely with very little play.
Apart from that... stick a bolt through the T-nut and lock it in place with a wingnut.
High efficiency 25hz sub - driver tips? Defo Subwoofers 27 8th August 2009 12:43 PM
two BIB questions re inner baffle and driver cutout drec Full Range 3 23rd December 2006 02:59 AM
Help installing driver when cutout wrong size morbo Multi-Way 19 9th February 2005 02:43 AM
Page generated in 0.07687 seconds (72.10% PHP - 27.90% MySQL) with 11 queries
