UcD400 Q & A
Yves Smolders said:
These guys have amazing stuff! Too bad you can't order online - I'm going to give them a call...
The DC protection is great (has its own power supply, I guess it keeps the relays open in case of problems)
I want the slow start as well.... :cool: You can use this to start the unit at audio signal (like a subwoofer)
And those 47.000uF Caps! :eek:
Are these good specs?
In the picture I see +/- 20% capacitance error... :(
I think they might have them custom made at BHC. In their standard range there is a very similar capacitor:
http://194.205.122.12/servlet/AdminBHC?purpose=spec&partNo=ALS31A473RD063
premmetje said:
It wouldn't be too difficult to add a second crowbar to accomplish simultaneous crowing ;). I left it out because I thought the bridge rectifiers would keep the reverse voltages out (apart from two diode voltage drops), but I guess that even the odd 1 or two volts might not be so good for some of the electronics.....
I was thinking a similar thing about the rectifier diodes. The question would be how much the surge current and voltage drop would be.
just a question about caps for the UcD400
i can get these caps from percyaudio:
Nichicon KG Series Gold
4700µF KG-Gold .......80V ..........$7.95...........35mm x 50mm
6800µF KG-Gold .......63V ..........$6.95...........35mm x 50mm
i'm not sure if i should get the 80V 4700uF or 63V 6800uF, if 63V is ok, i'll use a bank of 4 x 6800uF per rail, if i go with the 80V i'll use 6 x 4700uf per rail
i think the 63V rating of the caps can handle a surge voltage greater than the overvoltage protection of the UcD400 module (68V), is this correct?
the transformer that i'm going to use are two Avel 800VA dual 40V sec., this will be used in mono power supply setup.
thanks
Yves Smolders,
I use BGs for all applications barring primary supplies,for cost reasons!
The T-Networks are above average but like all electrolytics which use ion transfer they impart the usual grainy splashy colourations to the signal which the BGs do not. This is due to the much higher noise and distortion compared to BGs,which typically have a 60dB advantage.
Take a look at Martin Colloms`test report on BGs on the AUDIONOTE website where he and his listening panel were shocked at the improvements BGs gave over other well regarded capacitors.
At the very least you should replace all bypass electrolytics on circuit boards etc to hear the benefits of BGs,don`t just replace one or two and expect to hear big improvements;any conventional caps downstream will compromise the BGs performance advantages.
As for using resistor feeds with the T-Networks;OK for pre-amps etc but I would imagine not a good idea for poweramps where you don`t need any possible current limiting effects!
Bob Lewis
I just wonder if caps' effects are the same in AB and D class designs.
AB is a discrete signal that can have all kinds of interference before the amp.
D is a rapid on-off switch and has another kind of stress on the equipment before the amp.
My test sounded wonderful with nichicon (sp?) caps and a non-toroidal transformer, with a very basic rectifier from the old amp.
Sigh... decisions decisions... :confused:
Back in business
Well, as I wrote about 4 weeks ago, I ruined the modules for my stereo-amp (the three-channel works fine).
Finaly I got the new modules (the ruined ones were economically irrepairable) last week and finished the amp saturday. This time I did nothing wrong....
Well I am impressed, the amp sounds even better than the 3 channel (with 'old' UcD400's). I heard things I didn't hear before and the control is magnificent.
Frans
No, those Thel caps are made by Krummer and resold by several brands (Thel, Mundorf, Fischer)
I dont know if this offer still holds:
http://www.diyaudio.com/forums/showthread.php?postid=575084#post575084
Those quotes prices are very low! 23 euro, a similar Mudorf costs 96 euro (only that one is 80V)!
i found this nice looking chassis
"High quality aluminum chassis 17.5"x13"x3.25" Front and back plates .1875" thick custom extruded aluminum polished and anodized. Top and bottom plates .125" thick aluminum mirror polished. Chassis comes with solid, machined aluminum feet with felt pads and red oak wood sides with a tung oil finish."
i'm building dual mono w/ 2 800VA avel transformer 40-0-40 Sec.
my question now is how can I provide ventilation for 2 UcD400 modules inside, is it ok if I drill holes under the chassis? or do they have to be on the sides or top?
onixuser
enclosures
Has anyone found a nice simple (black preferably) extruded style enclosure with end caps to suit a UCD400 plus power supply monobloc style? Sort of like a Rowland 201 but without the need for the flash front panel?
thanks
Murray
ps have built a pair on "chipboard" - seem to outperform a well respected local amp. Great! Now I need a box!
pps a different world to some tripath amps I built - both in audio quality and rfi!
ewildgoose said:
The par-metal chasis looks nice. I think its all alu as well including the sides? I prefer the alu sides of the ones from audiokit to be honest, but they use nasty steel tops and bottoms. (OK, nasty is a bit strong).
By the way, where did you get the feet from?
The par-metal series 20 chassis is available in a variety of sizes and features all aluminum construction. The feet that I used are made by "EAR" (http://www.earsc.com). They are available from Partsconnexion and Percyaudio here in the states.
