TPA3255 - all about DIY, Discussion, Design etc.
Old 29th September 2017, 08:50 PM   #341
454Casull is offline 454Casull  Canada
Originally Posted by doctormord View Post
I'd guess, TI rigged them up just with some short wires to test them all.
Do you think this might have any negative impact other than a slightly messier layout?
Old 30th September 2017, 04:33 AM   #342
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
The real question should be with the output inclusive feedback loop if the higher quality Coil Craft inductors still make any measurable or audible difference vs a lower cost inductor? Dr. Mord would seem to have this answer with his TPA3251 board development.
Old 30th September 2017, 09:47 PM   #343
rhing is offline rhing  United States
rhing's Avatar
I think as long as the wires are kept as short as possible, it shouldn't be an issue. On the TI TPA3255EVM board, it looks like there is space on the bottom side to mount the Wurth inductors. This could be done by soldering short segments of wire to the two terminals of each inductor and feeding the wires into the through-holes where the stock Coilcraft inductors are mounted. I wonder why TI would determine that the Wurth inductors would perform better, yet design their EVM to use the Coilcrafts instead. This could be splitting hairs though, because I am enjoying the TPA3255EVM in stock form in my system.
Besides adding a pair of Altec Peerless 15335A input inductors to convert unbalanced RCA inputs to the differential (balanced) inputs of the TPA3255, I might try implementing the PFFB modification, which is easily accommdated on the TPA3255EVM PCB. I just need to try and dig my trusty Metcal soldering workstation out of storage.
Rich
Old 30th September 2017, 10:36 PM   #344
voltwide is offline voltwide  Ireland
There is no doubt that the TPA can be tweaked yielding a performance that is superior to the EVM.
But I presume it is not the intention of TI to present an EVM with highest performance with best parts available on the market - but more a reference for high quality with affordable parts.
Personally I think the EVM performs quite good and I really doubt that any of our golden ears could notice the difference to a more sophisticated TPA3255 design.
Old 1st October 2017, 09:45 PM   #345
doctormord is offline doctormord  Germany
doctormord's Avatar
At pure resistive load, the advantage is very minor, especially at output levels below 10W. With complex loads, PFFB might control your speakers better, but this is something i haven't "tested".
I.e. the actual board performance in PreFilter PBTL without an extra AFE and no PFFB is actually like so. (PVDD=30V, Load 5R, no heatsink:
TPA3255 - all about DIY, Discussion, Design etc.-steps_tpa3255_30v_5r0-png
10V = 25W
Plot taken by Voltwide. When using "low cost inductors" the advantage of PFFB is pretty obviously. Also/especially with TPA3118/TPA3128.
Old 2nd October 2017, 03:31 AM   #346
Thank you Dr. It would seem you would still want to use a high quality output coil but with the PFFB circuit going to the best coils as found without the output inclusive circuit may be overkill? Would it make a difference between the Wurth and CoilCraft inductors with the PFFB?
Old 2nd October 2017, 05:41 PM   #347
doctormord's Avatar
As said (also by Voltwide), it is some kind of hairsplitting. PFFB might tighten the control of complex speakers/loads. You'd better ask Voltwide about this. If you need to get better by like 0.002% THD at 1kHz compared to the coilcraft, you may try.
Regarding the Wurth inductors, their advantage mostly come from physical dimension/construction. I actually use Codaca inductors in place, Voltwide is using Ferrocore. (Same geometry)
TPA3255 - all about DIY, Discussion, Design etc.-img_9909-jpg
Old 3rd October 2017, 02:27 AM   #348
Thank you Dr. I think you've answered my question, use one of the better inductors and everything will be fine.
Old 4th October 2017, 09:08 AM   #349
sybic is offline sybic  Poland
My modifications :
Filter :
1.
choke CoilCraft VER2923-103
2.
680nF EPCOS instead 470nF
3.
NE5532 instead TL072
4.
6 x Nichicon Fine Gold 10uF in the signal path instead 6x22uF
5.
LM2575HVS-15 instead LM2575S-15
6.
choke in the stabilizer 220uH (221) instead 22uH (220)
7.
2k instead 2.2k (stabilizer LM317)
8.
220uF (Low ESR) instead 22uF (LM2575HVS-15 - 15V, LM317 - 12V)
9.
capacitor PVDD
1500uF Panasonic Low ESR instead 3900uF Elna(???)
10.
10k 1% instead 10k 5%
Old 4th October 2017, 09:47 AM   #350
Kjeldsen is offline Kjeldsen  Denmark
looks really good with the modified PCB add on, instead of trying to make it fit, on the original PCB.
As far as i remember, the minium safety distance between the SMPS PSU's is 5-6 mm. It seems to me they are very close, and might even touch each other?
http://kjeldsensforbindelser.dk
TPA3255 - all about DIY, Discussion, Design etc.Hide this!Advertise here!
Inexpensive HDMI 2 channel receiver design discussion brw02005 Construction Tips 1 6th March 2016 07:27 PM
A Discussion on Design Philosophy - OB vs Multiway vs NOB miragem3i Multi-Way 2 10th July 2014 03:02 AM
Discussion: push pull design and minimal distortion does it matter ? hoppaz Subwoofers 19 15th November 2012 08:34 PM
Car subwoofer (2x8" fancy design discussion) VEC7OR Subwoofers 11 29th May 2004 09:12 PM
