hi can anyone help me with this circuit - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th April 2012, 06:10 AM   #1
Default hi can anyone help me with this circuit
i got this circuit from this forums but i do not understand how it is work and where is the mosfet driver and why it use to different mosfets
Old 9th April 2012, 06:46 AM   #2
Pafi is offline Pafi  Hungary
MOSFET driver is Q4,5,6,7.
U1A: integrator, U1B: histeretic comparator. Basically it works like an NE555. C9 is charged until the comparator reaches the threshold, it changes the output polarity, and the capacitor starts to discharge (because of the current from R16). Input voltage makes discharging faster and charging slower (for positive input ploarity), so modifies duty cycle.
Feedback and integrator works as the usual 1st order feedback loop also, keep distortion low.
I quess you mean "two different".
Different MOSFETs are used because positive rail is different polarity from negative rail. N-channel MOSFET for negative, p-channel for positive. N-channel for positive is more complicated.
Old 9th April 2012, 07:27 AM   #3
oh thanks Pafi ....
U1D AND U1C are working as op amp ... ryt
Old 10th April 2012, 03:03 AM   #4
hi guys the function of Q1 and Q2 is to shift or what
Old 10th April 2012, 08:44 AM   #5
godfrey is offline godfrey  South Africa
When the output of U1B goes positive, Q1 switches on, pulling it's collector voltage down. This switches Q5 and M1 on, pulling the output voltage up.
At the same time, Q2 is switched off and current through R6 switches Q4 on. Q4 pulls the voltage on the gate of M2 down to switch it off fast.
Similarly, when the output of U1B goes negative M2 is switched on, M1 is switched off, and the output voltage goes down.
Old 10th April 2012, 02:51 PM   #6
oh ok .. so Q3 and Q6 do not have function
Old 11th April 2012, 04:00 AM   #7
hi guys is the function of UD is a differentiation op amp or what cause i do not understand how TL074 behave
Old 11th April 2012, 05:07 AM   #8
Yes they do! I only explained one half of the operation in detail, and hoped you would understand that the other half is similar. Here is the other half of the explanation in detail:
When the output of U1B goes negative, Q2 switches on, pulling it's collector voltage up. This switches Q6 and M2 on, pulling the output voltage down.
At the same time, Q1 is switched off and current through R5 switches Q3 on. Q3 pulls the voltage on the gate of M1 up to switch it off fast.
TL074 is a quad opamp. That means it is one integrated circuit containing four opamps. In your circuit, U1A is an opamp, U1B is an opamp, U1C is an opamp, and U1D is an opamp. Each one is just a normal opamp, but they are used in different ways.
Class D is the most difficult kind of amplifier to understand. You don't seem to know much about electronics. This is a bad combination.
Why do you want to make a class D amplifier in one week?
Wouldn't it be better to start with something easier?
Old 11th April 2012, 08:10 AM   #9
YEAH I KNOW I HAVE LITTLE INFO ABOUT ELECTRONICS BUT I M INTEREST IN CLASS D ....what i mean when i said i do not understand TL074 behavior i mean in this circuit how it is operated
Old 11th April 2012, 09:32 AM   #10
C1, C2, R18, R23 and R24 are all marked "DNP". Does that mean "Do Not Place", or something else?
If those parts are left out then U1D is a unity gain buffer. If those parts are included then U1D has some gain and the frequency response will be changed.
Where on this forum did you find the circuit? Maybe there is other information there that can help. Can you give a link?
With painted a circuit, STI(2SK182E) pipe of the SRPP circuit, is feasible? lgqliu Solid State 2 25th February 2012 06:07 PM
EQ Circuit before or after crossover circuit ?? abel2b Analog Line Level 6 27th April 2011 08:44 PM
This circuit ok? CarlyBoy Tubes / Valves 6 26th February 2008 03:28 AM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
and this circuit takashi Digital Source 4 17th June 2003 12:54 PM
Copyright 1999-2017 diyAudio
