Go Back   Home > Forums > Amplifiers > Class D
Old 22nd February 2013, 06:44 PM   #371
Originally Posted by apexaudio View Post
Nice work, coil isn't rewind?
yes sir, the coil is not rewind, i have 1mm wire, how many turn should i wrap the core ofthis kind ? Regards.
( sorry, i,m using google translate to wrote)
Old 22nd February 2013, 08:11 PM   #372
apexaudio's Avatar
Originally Posted by suryadi5417 View Post
at last my D200 is singing.... using coil from computer psu and not hot just warm, i,m HAPPY now... YESSSS
What is rail voltage on your amp?
Old 23rd February 2013, 04:30 AM   #373
manojtm is offline manojtm  India
manojtm's Avatar
Hi mile,
did you check D200 @75V rail??
is it start(oscillate)@very low signal input without noise???
feedback resistor 4k7 hot???
MANOJ
Old 23rd February 2013, 06:54 AM   #374
apexaudio's Avatar
Originally Posted by manojtm View Post
Hi mile,
MANOJ
This D200 work at +/-80V rail, only 2k2/2W and TIP31C are hot.
It start at very low input signal without any audable noise.
Old 23rd February 2013, 08:10 AM   #375
manojtm's Avatar
Hi Mile,
thank you
Regadars
MANOJ
Old 23rd February 2013, 08:34 AM   #376
manojtm's Avatar
Hi mile,
actually Mackie SRM450 using 4k7/2W series with 47K/0.25W for feedback and it will HOT little @35 degree.
MANOJ
Old 23rd February 2013, 09:41 AM   #377
apexaudio's Avatar
Hi mile,
MANOJ
For me over 60 degree is warm and over 90 degree is hot.
Old 23rd February 2013, 02:17 PM   #378
apexaudio's Avatar
Default D200.2
With 3X1k5/1W instead 4k7 and 4k7/2W instead 2k2/2W there will be no heat problem at +/-75V rail
Old 23rd February 2013, 02:37 PM   #379
just for testing i'm using 42v dc.
Old 23rd February 2013, 02:43 PM   #380
Originally Posted by krakow View Post
Hello,
what is the brand of the 0.47µF and 0.22µF capacitors?
Because my seller don't sell WIMA capacitors.
Scuse my Frenchy English
my caps 0,47uF and 0,22uF with no brand, i think from china.
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright ©1999-2013 diyAudio
