Nice work, but there is mistake.
Oh , that my mistake thanks you so much for checking .
I've edited .
Regards .
I've edited .
Regards .
hello thienchay..
great job!! I would like to ask..
what the rail voltage for 2 Ohms, 4 Ohms & 8 ohms?
what mosfet use?
what value of filter inductors?
how many watt in 2ohms, 4ohms & 8ohms?
hope to hear you soon... thanks for the lay-out..
hello thienchay..
what mosfet use?
hihi , i'm not yet try it the value of filter inductors is around 22uH -> 47uH for 2 ohm -> 8 ohm load .
you can rail around +/-55V -> 65V for 2 ohm load (i think it can work with +/-75V) , i have IRFP450, IRFP460 so i'll use it . You can use another MOSFET with the same datasheet .
thanks thienchay!!
nice to hear you.. I have IRFP460 on hands.. so then I will use those mosfet..
I've edited .
Regards .
Use BD241C or TIP31C... instead IRF640 in 12V bias circuit.
ok sirUse BD241C or TIP31C... instead IRF640 in 12V bias circuit.
Thanks a lot
hi apex
can i use this limiter in your class d amp
thank you
regards
ravs..........
Yes this limiter will be ok,
Hi Apex
Are you propose what speaker protection for this amp ?
Use 'speaker terminal' DC protect with triac from SR200 thread
Hi thienchay,
Nice PCB, Thanks
Is't IRFp460 Qg (210Nc) quite high for 2 pairs O/P, even for 200 - 250Khz.
Mr.Mile I still have the same problem, now I have 17.5v Dc on the O/P ,, will look at any other fault in the PCB.
I will make thienchay PCB and Build the amp.
regards
Nice PCB, Thanks
regards
Hi Apex..\ Thienchay..
I'm Planning to build this amps that lay-out from thienchay..
before make this project I want to make things clear as my project plan..
I will use +/-63v my target load is 4ohms.. I will use inductors coil from Coilcraft VER2923-223KL
http://ph.element14.com/coilcraft/ver2923-223kl/inductor-pwr-22uh-26a-0-1-12-2mhz/dp/2289007
kindly check my attach photo..
VER2923-223KL - COILCRAFT - INDUCTOR, PWR, 22UH,26A,0.1, 12 | element14 Philippines
hi dc sound
this board is not mine.thats a u core salvaged from
flyback eht of monitor.
regards
ravs.....
Hi, Thien Vegetarian
You can send your Sprint Layout original file for me?
my email: uidanoob@gmail.com
Thank you
Thank you
Hi Thienchay/ Apex,
the caps 100uf/100v in the positive rail is wrong polarity.
here's my PCB of Apex turbo.. kindli check for any error..
yeah , you are right . that my mistake , so sorry , the capacitor in your redraw pictures is right , my original is wrong , thanks for check
- Class D
- Class D Amp with LM566, LM393 and 2XIRF530
