ucd 25 watts to 1200 watts using 2 mosfets - Page 6 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 17th May 2010, 07:50 AM   #51
MOER is offline MOER  United States
Default Ucd
I have examined the schematic and there are several issues which will cause serious problems.
1) There is no provision for any dead time
2) The MOSFETs shown are old, slow and are not suitable for high frequency switching
3) The gate resistors should be reduced to about 4.7 ohms and use IRFP4229 or some of the newer INFINEON MOSFETs which are superb.
4) The snubbers across the output MOSFETs reduce the resistor values to about 10 ohms.
5) Use 0.1mfd 100v chip caps ate the actual pins of the MOSFETs to ground (Upper Drain and lower Source)
6) Use a bunch of 0.1mfd 200v chip caps from +40v to -40v as close to the MOSFETs as possible.
7) The UF4004 bootstrap diode is too slow use a 35nsec 200v diode.
8) To keep the output offset low a servo MUST be used from speaker output to LM311 pin 2
Steve
Old 17th May 2010, 08:27 PM   #52
qsa is offline qsa  Germany
qsa's Avatar
Steve
Im a little confused because in Spain DIY Forum the amplifier should working very good..
can you add important changes in schematic and share your experience and knowledge with us ?
Old 18th May 2010, 01:33 AM   #53
andrewlebon's Avatar
hi workhorse
greetings any comments on schematic any mistakes any sugesstions with your expertise this project can be possible for all d class
fans hoping you can help
thanking you
andrew lebon
Old 18th May 2010, 03:57 AM   #54
Originally Posted by andrewlebon View Post
hi diyers
greetings can this circuit work are there any flaws
thanking you
andrew lebon
this might help. also use same translator. Google Translate
There is always a first time....
Old 18th May 2010, 04:32 AM   #55
2 details of coil 33uh wire diameter no of turns core diameter
Shavano Music Online - Cross-Over Network; Air Core Inductor Calculator
Use above link
Hey and did u check about availability of IR2110 and other components? I fear it might not be easily available here in India.
And guys. can anyone provide TS of this amplifier. ( like Frequency response, Inter-modulation distortions, THD, slewrate)
Old 18th May 2010, 10:04 AM   #56
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
In the kingdom of the blind the one-eyed are kings, but here we are in a two-eyed forum.
This amplifier in some cases can play loud music without overheating or destroying itself, but the design is full of pitfalls. In fact, those pitfalls make the result quite random, some units will work and some won't, depending on parts, etc... (too many parameters overlooked by the designer).
Electromagnetic interference will be quite high too.
I use to feel like the small child in The Emperor's New Clothes tale
Old 19th May 2010, 01:40 PM   #57
Reactance's Avatar
Always complaining and criticizing other peoples work. its a good starting point no one has provided a better simpler class-d solution not even you, and yes, your good clever answers can only help so far.
There’s nothing worse than the smell of burned output transistors!!
Old 19th May 2010, 02:39 PM   #58
81bas is offline 81bas  Germany
Have you already tried to build this simple amp with its "very good component selection"? Any photos?
Old 19th May 2010, 03:58 PM   #59
Reactance's Avatar
no but you don't see me complaining and criticizing other peoples work i take you and eva have something in common then.
Old 19th May 2010, 05:24 PM   #60
just try to build this amp and get it working, it is "so simple" (please do not forget to post some photos). I am pretty sure, there will be some troubles with it, but we do not see you complaining and criticizing then
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 91 16th December 2016 04:56 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
