hi to all!!! at first when i build the amp ,the IR2110 was FAKE! i bought 2 off them both FAKE! after i bought the third IR2110 the amp came to life.....the sound is just amazing...very clear ...i use IRFP260 they are cold ....the output coil is hot..i use a toroid from an old pc power supply ....but even with that the amp works very well and sunds great...(sorry for my english)
http://s957.photobucket.com/albums/ae59/ionutzxpo/?action=view¤t=06062010005.flv
hi dear
what voltage rails are you using
thanking you
He uses +/- 28Vdc for the moment for tests.
After all is tweaked and the SMPS is ready we will connect it at +/- 95Vdc.
Savu Silviu
Savu Silviu
do you have any idea how to add effectice short circuit and overcurrent protection..?
I think this is important thing
Just to give you some ideas... Using a 555 monostable, some transistors (or perhaps, a plan comparator, you can easily use the shutdown input of the IR211x to implement an overcurrent/short circuit protection protection
can you offer schematic ?
its new for me ....
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
