ucd 25 watts to 1200 watts using 2 mosfets - Page 366 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 28th August 2013, 06:37 AM   #3651
andrewlebon's Avatar
Hello
greetings why do CROWN XTI9000 have 4 T157-2 cores as output filters PER CHANNEL
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 28th August 2013, 07:18 AM   #3652
PetruV is offline PetruV  Romania
What is the link to irs900 and irs3000 pcbs?
Just a kid who likes building and modding things.No inspirational quote here for you
Old 28th August 2013, 01:27 PM   #3653
Originally Posted by stewin View Post
thanks for the reply . i am facing serious issues with irs900 both thienchay and detex they work for a short time or a few days and fail i have had three different experiences .in all the above the voltage was
>>> +/- 70vlts about 6amps and filtering caps were 6800uf per rail.
>>>the load was 3ohms to 8 ohms
>>>all the output fets were one pair irfp250n
>>>all the inductor i used was etd 33 or ee 33 , 15turns and 1mm gap on both legs using a piece of CD or DVD disc
>>>switching frequency was 250khz normal on the thienchay and detex layout
two projects had two channels one project had four channels.
i am thinking maybe busspumping, slow fets ("but dismissing it because big proffesional companies powersoft use irfp250n") , non ucd topology or core saturation . please help i am really confused .
i have another irs900 three channels which has survived for one year plus without any issues except bowing fuse when one output of either channel ,a speaker or load is disconnected when the amp is on. all the specs are like the above except the voltage is +/-39vlts.
i will post photos later.
Did your IRS900 fail at startup? If yes it's possible that you have a startup problem described here. Check the time constant of your bootstrap supply...
Since IRS900 doesn't have overcurrent protect, high side latching at startup will cause both mosfets to blow.
amplifier PCBs and modules
Old 28th August 2013, 07:12 PM   #3654
stewin is offline stewin  Kenya
thanks lester. i think that is the best explanation. because i had build manojs great amp aud600 three channels with protection board , it worked well and very fine even when using a generator instead of ac from mains. voltage was +/- 60vlts output fets were irfp250n .
but when i did not use the protection board . it failed even at startup even without a load same case as irs900d. and the case was not one board but different experiences.
Old 31st August 2013, 04:58 AM   #3655
Default IRS1500 STEREO PCB
Sameerx1 new IRS1500 stereo pcbs double side
warm regards
andrew lebon
File Type: jpg 1148845_202438549917588_1666567237_n.jpg (126.9 KB, 1548 views)
File Type: jpg 1229811_202438573250919_50477389_n.jpg (115.2 KB, 1495 views)
Old 1st September 2013, 01:21 AM   #3656
Default spw52n50c3
Manufacturer: Infineon
Product Category: MOSFET
RoHS: RoHS Compliant Details
Transistor Polarity: N-Channel
Drain-Source Breakdown Voltage: 560 V
Gate-Source Breakdown Voltage: +/- 20 V
Continuous Drain Current: 52 A
Resistance Drain-Source RDS (on): 70 mOhms
Configuration: Single
Maximum Operating Temperature: + 150 C
Mounting Style: Through Hole
Package / Case: TO-247
Packaging: Tube
Fall Time: 10 ns
Minimum Operating Temperature: - 55 C
Power Dissipation: 417 W
Rise Time: 30 ns
Series: xPW52N50
Factory Pack Quantity: 240
Tradename: CoolMOS
Typical Turn-Off Delay Time: 120 ns
Hello
greetings is this mosfet suitable for class d amps as its easily available
made by IFINIEON
warm regards
andrew lebon
Old 1st September 2013, 09:02 AM   #3657
some class d amps in working progress,
triell 3200, detex audio irs3000d, srimodify 3200i.
Old 1st September 2013, 09:05 AM   #3658
core is not suitable for class d
warm regards
andrew
Old 1st September 2013, 09:17 AM   #3659
yes, but its working fine,
next week i am going to thailand, and i will buy that core, because in my country not available.
Old 3rd September 2013, 01:42 AM   #3660
Default limiter
Hello Sameerx1
greetings heres the limiter
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
