Go Back   Home > Forums > Amplifiers > Class D
Old 7th December 2012, 09:59 AM   #3011
manojtm is offline manojtm  India
manojtm's Avatar
input gnd and output gnd is same in car converter then amp gnd and cd player gnd and bias gnd is same
what can i do ?
Hi Hadi,
Use 12v7AH BAT(old UPS like 300VA/500VA/600VA using this ) for 12v bias(testing only).OR use separate winding for bias supply
can you show me the schematics / pictures.
MANOJ
Old 8th December 2012, 11:13 AM   #3012
i dont have shematic for that sir manoj
Old 8th December 2012, 11:13 AM   #3013
i must use separated winding for bias
thanks
Old 9th December 2012, 08:47 AM   #3014
andrewlebon's Avatar
Default class d amp and smps
Hello
greetings 3 pair IRS3000 getting packed with smps in crown cabinet
need higher power smps
warm regards
andrew lebon
[image][/image]"It's Better to try and fail than to never know and always wonder"
Old 9th December 2012, 11:21 PM   #3015
Originally Posted by don2007ksa View Post
To chago25,please check
this corrected
this right now
Uploaded with ImageShack.us
Nano
Old 10th December 2012, 03:44 PM   #3016
Default hi,
Originally Posted by andrewlebon View Post
Hello
warm regards
andrew lebon
hi andrew,
greetings,
are you like to clone any branded amplifier smps for high power output,
if you like try QSC power-lite3 amp smps
Old 10th December 2012, 07:05 PM   #3017
Hi
thanks sir manoj for your best quality amp
Old 11th December 2012, 06:49 PM   #3018
stewin is offline stewin  Kenya
Hello
warm regards
andrew lebon
what voltage did you use with irfp260n ?
Old 11th December 2012, 11:21 PM   #3019
HI Stewin
greetings 80 volts dc +/- used with IRFP260N
warm regards
andrew
Old 12th December 2012, 05:35 AM   #3020
Workhorse's Avatar
Hello
warm regards
andrew lebon
What sort of joke is this Andy.
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
